Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
turbo
Quote from: z_p_e on June 19, 2007, 12:33:35 AM
I was going to wind a coil, but I don't have the #24 wire, so I decided to try and calculate the inductances.
What I came up with:
Primary: 15.5uH, 0.36 Ohms, [165.32 inches of #24 wire], 90 turns
Secondary: 107.8uH, 2.28 Ohms, [413.28 inches of #28 wire], 248 turns
I used a coil length of 1", and a starting bobbin diameter of 0.5".
Hopefully a few people will add their specs for comparison.
Regards,
Darren
248/90=2,75
2,75x12=33
33x3=99  ::)
MrMag
GK,
CC - Control Coils - 1" width
Tubing for collector = 1/2"
Tim
giantkiller
Quote from: MrMag on June 19, 2007, 04:28:43 PM
GK,
Tim
Geez! Thanks. I must have put my brain on backwards today.
--giantkiller.
MeggerMan
@Roberto,
The divide by "n" device CD4059A you have mentioned is an excellent idea, BUT I think you need to still need to feed it with a function generator to get desired master frequency to start the divide by.
Feeding it with a xtal oscillator will limit the number of output frequencies.
I plan to do the same thing and this device is just what I have been looking for.
@Jason,
Although your function generator boxes do not support duty cycle control, you can however simply have an op-amp connected to the triangle wave output.
You adjust the -ve bias using a trimmer on the op-amp to determine at what point the op-amp turns on and off. Then using the amplitude control on the function generator you can set the duty cycle.
Simple.
I still have to test this with my DDS 20 function generator, except I have to use the sine wave output as the feed to the +ve bias of the op amp, not quite as good as using a triangle wave output, but it will do.
Not sure about the ripple counter idea, I think you would be better with what Roberto has suggested with 3 X CD4059A.
I think this is the way everyone should head towards, as this guarantees a synchronised signal in all 3 control coils.
@All
I have ordered up two more DDS 20's in kit form this time, so its going to be callenging soldering up the surface mount AD9835 chip with 0.5mm pin spacing.
I was thinking what WaveWatcher was saying about the clues in the post from SM, maybe it was SM himself???
I was trying to figure out the tie-up between 35.705KHz harmonic and 245KHz output.
So what combination will fit them together exactly?
Maybe 245KHz was a ballpark figure so as not to give the farm away?
If you have:
249.935KHz / 7 = 35.705KHz
249.935KHz / 5 = 49.987KHz
249.935KHz / 4 = 62.48375KHz
These would all be in perfect sync if you use 3 x divide by n devices all fed from a common function generator.
Also, there has been no mention of a tuning capacitor so the coils can be tuned to their harmonic frequencies.
Rob
Bruce_TPU
Quote from: MeggerMan on June 19, 2007, 06:30:57 PM
If you have:
Rob
@ Rob
Now that is the kind of thinking that is going to move us to the next power level!!  :)
We will find one day soon, that those frequencies fit in some how.
Cheers,
Bruce
