Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
dlwammo
Is this anything that might help?
US Patent#:  6,496,047
One of the inventors names is "Stephen Mark" Iskander ???
Filed: June 23, 1999
SOLID STATE SWITCH WITH PULSE CONTROL
Seems rather interesting.....
Dan
Don't mess with old farts... age and treachery will always overcome youth and skill!
z_p_e
For those that may be interested, below is a circuit that should work well for a harmonic divider. I specifically altered it to provide a fundamental, 2nd harmonic, and 3rd harmonic.
The frequency you put in, is the f3 (higher) frequency. f1 and f2 are generated from this.
Dave has built this circuit and verified it works. Below the circuit you will see the simulated output waveforms, which also verify it works.
Please note however, that the f2 output is 66% duty cycle, not 50%.
Darren
z_p_e
Quote from: ronotte on June 20, 2007, 12:44:09 PM
@Darren,
Yes, in that sense we are speaking of the same final effect which is important.
For what I've seen the 'Seed' is created by a sweet combination of the 3 frequencies and from the catalyst field produced by the Mobius loops which MUST accelerate any particles (electrons, ions...) that appear to be in the nearings (tested experimentally: if you increase the heath sink modules distance from the ring...the Seed disappears!).  Then saying how is the creation process is really for now impossible. I urge every body to think about this!
Roberto
I was wondering if anyone else picked up on something Roberto said in his post above. I've highlighted the important point.
The possibility that RFI feedback from the wire loops is causing the "seeds", should not be dismissed.
I do believe this is what is causing the seeds. The effect is proximity dependant. With the FETs far enough away from the loops, the seeds disappear.
A piece of wire driven with high current transients and high frequencies, no longer is strictly a piece of wire. Inductive reactance is going to be present in the FET gate, and this coupled with the high input resistance seen looking into the Gate could be causing the artifact being labeled as "the seed".
It is quite evident from the tests done so far that there is significant RFI being radiated by the loops, which makes this hypothesis quite plausible. The large metalic surface area of the heat sinks are probably acting as good receiving antennas, and re-radiating the RFI.
See the annotated diagram below.
Regards,
Darren
c0mster
Also scope your Fets an look at the BEMF spikes, turn your probe to *10, those fets are getting hit hard.
I added a small cap to my primary and it increased the output of the light. Why because now the primary is acting more like a tank ctc and oscillates giving the secondary more punch.
Cam
kokomoj0
Quote from: bobinaccounting on June 20, 2007, 08:04:12 PM
Quote from: MeggerMan on June 20, 2007, 06:39:44 PM
@Wavewatcher,
Here's another thought I have been having:
Maybe the three coils can setup a magnetic magnifying lens that pulls in a massive concentration of magnetic earths field from above and below the ring. This magnetic field (vortex) induces the power in the output coils of the TPU.
Thats what I said, vortexes!
so how much "massive earths magnetic flux" do you need to run a tpu?
Then does the earth just sit here and constantly resonate at 7.8htz or can it made to resonate where its resonant freq is 7.8 htz?
