Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
Hoppy
I do not wish to sound negative with this question but think its important to answer: -
Do Otto and Roberto intend to rerun their tests using a 12V battery for the power supply then measure and report the DC current taken to illuminate their light bulb at the brightest level possible using  three frequencies?
giantkiller
Quote somewhere: 'There are many ways to get there'.
Fact: SM has shown us 3 different types of TPUs.
Statement: 'When we were a child we spoke as a child'
Question: Why does this have to take so long?
Answer from one who used to rant: 'He who whines wants what they have not earned'
Otto & Roberto have shown a 4th physical model, albeit not finished.
And without the responsibilty of work comes not the reward of respect for what one has achieved.
I am happy with all the results so far by everyone. How's that from someone who is running the race?
--giantkiller. Guaranteed: Those who rant haven't seen RE spikes on their bench yet. :o ;)
@Stefan, I like the quantum physics in the sidebar. Nice touch. :)
CTG Labs
GK,
As you know I have tested several TPUs and I have seen many HV spikes.  Can you explain to me please what makes them Radiant Spikes (whatever that is) compared to simply inductive high voltage spikes?
Thanks,
D.
gn0stik
Quote from: hartiberlin on June 21, 2007, 11:56:45 PM
Okay, kokomoj0  I have set you now on Read Only access.
Regards, Stefan.
And the crowd roars.
Hey, wavewatcher. When are you gonna make your own thread? I'm interested in hearing more about your research.
@all, as luck would have it, just as I got my cct built (mostly), we got 2 acceptable offers on our house. As we were countering one, a full price offer came in, so we're all wrapped up in real estate stuff right now.
Then get this, my car started acting like it wanted to give up the ghost, so I'm putting that in the shop today and getting a rental car. When it rains it pours. Perhaps god's telling me something?
Anyway, testing my tpu is on hold until I get a break in the clouds.
Good work stefan. Stuff like that is one of the main reasons I left here before. People like that went completely unchecked before.
Thanks,
Rich
Bruce_TPU
@ Rich
WaveWatcher started his own thread in the news section:  "Bird on a Wire".
He gave all of us the secret to turn the ECD into the real deal for which I am grateful.
He wrote:
"If the same frequency is applied to both rings (of the mobius) going both directions with separete signals and the rings are inductively coupled to propogate that signal back and forth between rings a multitude of spawned frequencies would emerge. Each taking the same path and spawning more of the same until the mechanics of the process could not support higher frequencies without serious attenuation."
THAT is the SECRET to make more power from our "baby" TPU.  This is the real deal.
So there we have it.  Case solved.  Secret's out.  Can we control it??  That will be the next "hard part".
Bruce
