Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
0 Members and 31 Guests are viewing this topic.
Mannix
Quote from: wattsup on June 29, 2007, 04:31:08 PM
@all
1) Frequencies will always be subject to the particular device.
2) You will not find one set of frequencies that will work for all devices.
3) There will eventually be a tighter range to work with, as Ronotte is trying to explain, but you will always have to fine tune each one individually.
4) Nature has its own way of dealing with harmonics that is generally not in a uniform, cut and dry manner, such as mathematical or musical designs. Random events can produce the best homogeneous results.
For me, the most important thing right now to find out is, if you are destined to make this device eventually self-operating, then you have to consider the device to be operated in two stages.
First stage start up with only mV input, pulsed into the primary CC and captured by the secondary CC into a capacitor plus capture the BEMF into another capacitor until you have enough power to run the power hungry frequencies (or you have to reduce the power consumption of the frequencies).
If these pulses (without a frequency) can produce enough start-up current, then you know your CC configuration is on the right track and you can then look to stage two.
But if you only look and work on stage two (massive current with frequencies) and the device cannot start-up with only mV's. Then this device will never be self-operating and you will have to re-work the start-up.
So my question would be, can the CCs alone, if pulsed with mVs or 1 volt, produce at least 6 volts into a capacitor. If you can just achieve this one criteria, then things look good and you can start with 1 frequency. If not, then the CC's or the general design has to be modified first to accomplish this. Afterwards you can work to get the right frequencies. Macedonian started a thread on something that could be a good place to start stage one. He's using a bifilar using only a few watts.
So some of you, like me, who are not on the top of the electronics ladder can start doing some easy pulsing tests into the ECD (no frequencies required) to see how this can produce a successful stage one. Maybe start a new ECD thread for stage one only to not crowd these guys. If this is impossible, then the overal design is flawed. While this is being done by some of you, others can continue working to better understand the frequencies, especially, where the hell these frequencies should actually be injected without wasting so much juice.
If any of you can supply any easy (nyophite proof) pulsing circuit that can work on 1 volt or less, 1/2 for the circuit, 1/2 to pulse into the CC primary at around 250,000 cycles per second, I think this will do. If the pulse could be variable, this would be better.
Last point, but you are not going to like it. Stop talking about SM. He is a total distraction to this endeavor. Stop talking about him and start using your own brains. There is over 9000 posts on SM so what more is there to say? Take back your power. THIS IS NOT A TPU, THIS IS AN ECD. The only power that SM's TPU is drawing in, is your will power. Every few posts and someone starts saying SM said this, SM said that, Enough already. I feel like we're being wacthed by the SM police. Who's spending all these hours, days and months? The guy's a loser for having shafted the world and you guys venerate his every word. I can say alot about this but will not say more here. Stefan, I know. Stay tuned to a new thread near you.
YEP ! feathers ,as predicted...duly..ruffled!
good points you raised..BUT you have lost it on your last
paragraph,
I for 1 suggest that your manners and asumptions are in question and let me ask you what point there is in sharing your ungrateful attitude .... I know that you are frustrated but spare  the messenger or messengers from your grief and failure to take responsibility for your inability to reverse engineer something as complex and important as this.  Bring what you can to this ..I have other have recently brought more ...the process is actually working.
Its not for everybody its  HARD ....real hard...and I ask that you think twice...or just once  before exspressing your grief here ... It is of absolutely no assistance to anything here ...even your self.
we will look back at this and say how simple it is...
If you have your own Ideas about another generator..then go for it ..start another thread...make a thread called " I JUST DONT GET THE TPU"  see how long it takes you to get it! Beet stil make one called "I GIVE UP" that will helpsomany people too.. just ignore the videos..the engineer reports..the witness reports..all the snippets of info that help in small ways...
Jump in your hole by all means, you dont need to advertise the fact that you are defeated by some of the info...Info that Im afraid may only be seen clearly with hind sight.
Calling somebody a "loser" merely makes clear to most,who is the loser here. More sadly the loss you cause could be everybodys.
You are lost, thats ok...just be nice!
It is great that you are building ,and i do agree with your first points.But can we please get this thread back to ECD replication?
Lindsay Mannix
Bruce_TPU
Hey guys,
Just a heads up... An OU claim is coming tonight.  It is a "type" of TPU is all I can say.  They will tell you all about it and post pictures.  Just please do not overwhelm or bombard this person.  But stay tuned, it could be a very exciting night!
Happy, Happy Days!   ;D
Bruce
bob.rennips
Otto, Roberto, Renotte, Jason, Bruce et al.
I've been doing some experiements and found that you can build a huge electric field that you can capture, transfer and pulse. Imagine entraining the ionesphere by pulsing ONLY the electric field at the schumann resonance. In other words cancelling the effect of magnetic flux. This electric field can be rotated. Electrons will follow the electric field. No flux to hold the electrons back as you are only rotating an electric field...
The salient stuff starts here: (but may need context of whole thread).
http://www.overunity.com/index.php/topic,2607.msg37572.html#msg37572
Basically you add some series diodes to both wires of every coil. This allows the electric field to build and hold at phenominal levels. This is not the same as step charging a capacitor. Stick your oscilloscope probe on metal objects feet away and observe the 5-10V (not millivolts, volts) oscillations on these objects. Exactly the same circuit but with the diodes shorted does not exhibit these oscillations on distant metal objects. You can only pick up millivolt mains oscillations at 50hz (60hz for those with 60hz mains AC).
Think of the energy in a tornado, the lightening, due to a rotating electric field. I'm sure I've read, a couple of years ago, that tornadoes emit a schumann resonance electromagnetic wave. Trying to find a reference on this. If any one has a reference on this please let me know.
bob.rennips
Quote from: btentzer on June 30, 2007, 11:26:49 PM
Hey guys,
Bruce
Rock on!! Could this be Earl's work ?
Due to time zones 'tonight' can be hard to determine. How many hours from now approx. will that be ?
chrisC
Hi Bob:
Wow! Is this IT?
Maybe we'll induct you into the Hall of Fame, together with Otto and Renotte!
Looking forward to exciting times! Great job!
chrisC
