Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
0 Members and 23 Guests are viewing this topic.
ronotte
Hello Bruce,
I'm waiting for a much better tests documentation! so go-on, clear the mess onto your table, put the Mosfet heat-sink NEAR the ECD (it means : in contact) then start your tests safely using firstly, just to search for freqs, PS voltage of no more of +6V. So you can have all the required time to setup Oscillator's level, freq sweet point (just start with an high range (100 -200KHz) it's easier and you don't risk to smoke anything! ..then medium range and only at the end the most dangerous low freq (20-80KHz).
But please put your scope probe on Phase point to look for sinus!.
Roberto
Earl
Roberto,
aahhh, you are meaning the drain to source intrinsic diode in each FET?
Because of large voltage change on drain, this reverse-biased capacitance could act as a varicap and also introduce a large capacity change during rise and fall times.  This may be a factor which is non-negligible.
This effect might change if using MacedoniaCD and Bob.R's two series diodes.
Interesting experiment to compare with 2 series diodes -  and with none.
This would not be present in a vacuum tube switch.
Regards, Earl
Quote from: ronotte on July 04, 2007, 05:53:01 AM
@Earl,
In ECD THERE's a MIXER and it's highly non-linear (logical kind mixer): all Mosfet's Drain pins are connected together.... there all the frequencies are indeed mixed and putting a scope probe there (ZERO point) you will see every kind of said by-products they make almost impossible to synch the scope trigger! There you can also appreciate some of the main mixing envelopes as if you select the right scope 'time line' it is possible to appreciate the main produced sum & differences frequencies just looking at the waveforms's envelope.
Roberto
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
ronotte
Hi Earl,
this 2 diodes for 'isolating coil' after turn-off time is  somehow new and is intringuing me...I had already planned to check the effect. I'll do it easily probably this evening !.
I'll report on it.
Roberto
Bruce_TPU
Thank you Roberto!
I think perhaps we have the ECD control coils wired incorrectly.  Have you looked at the "simplified" diagram in the FAQ, to wire the ECD?  Is it accurate?  If so, I will follow that, and rewire on next attempt.  Also, what fried our driver, was some of the leads we soldered to it touched and it smoked.  No problem, we have plenty.
I recommend to anyone building the circuit to use the other driver that Jason is using, simply for ease of use.  This driver is a booger to hook up because it is so tiny.  (for us inexperienced electronic people)
I also still think someone could make a mint, selling some of these, preassembled.  ;)
Cheers,
Bruce
ronotte
@Bruce,
please make reference to attached pdf for detailed ECD only dwg. For any problem PM me.
Roberto
