Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
0 Members and 250 Guests are viewing this topic.
giantkiller
Quote from: BEP on July 09, 2007, 09:50:19 PM
Wouldn't it be interesting if members of this forum - and others- were the actual reason for the flying saucer stories?
Hmmm.... Maybe that part of history didn't exist until we started mucking around now.
Most of the descriptions sound like TPUs being built by hobbyists in their garage. A circular saw blade?
On second thought maybe I better try one.
EVERYBODY DUCK!
See the movie 'Primer'. That is all I can say without giving it away.
IS' avatar was a saw blade! Remember?
--giantkiller.
ronotte
Hello all,
my lab is re-structuring but I've had enought time to complete my next ECD evolution that I named ECD V1.1. This advanced ECD has been designed, after discussing with Otto, to enhance mainly the particles release process always seeking to get more power in a safe way.
The ECD is now structured on 2 annular finned disks of 2 metals: Al and Cu, . The choose was made after carefully analyzing previous results. As shown in pic the disks are 'finned' ....VERY IMPORTANT.
Between the two disks I put the 3 Power Mosfet in order to allow them to heat the disks themselves!  (...and the CC as well).
I made small boards, as shown on the pic., where to put all the driver circuitry. So now finally I get rid of all the hash! The distance of Mosfet's Gate from the driver is now less than 1 cm. All the signal cable are now heavily shielded and the ECD itself is 2 metres far from all the other instrumentation....no more tampering problems and safer for me as well (but the television set just one level up is still tampered with).
About the waveform pic I must say that is referred to the use of only one CC and 3 freqs: 30, 90, 180KHz and +9VDC from the P.S. The upper trace is on ZERO wire and of course the lower trace is for PHASE wire of the load (60W/230V lamp) which is connected to an auxiliary secondary winded over the other coils.
Please note that only 4 peaks are converted in sine pieces. On upper trace it is possible to see 4 or better 3 Seeds....THAT'S VERY IMPORTANT because is the first time both me & Otto are seeing this....probably is due to the presence of 3 Fins on the disk! Please note that the sinus freq as always is 50 KHz.
Next step is to build the other two CCs and this time  SEARCH FOR POWER.
Best luck to all
Roberto
gn0stik
Roberto, it's looking more and more like the open TPU every day.
Looks very nice. Quite a bit of work involved there. How did you cut your copper and aluminum plates by the way?
Also, can you turn it off and hold it up and take a picture? I'd like to see it from the AL plate side.
Interesting development on the multiple seeds there. It seems like it may be necessary to increase the number of pulses to try and match the number of seeds somehow in order for them to have something to convert. Or perhaps get them to coincide better, it looks like it maybe has a tendency to alternate between spikes and seeds now. Also, that wave form on the lower half of your scope is intersting, how the spikes together create a sine all the way across the screen.
Thanks.
Rich
hartiberlin
Hi Roberto,
well done and nice new design.
Could you please let us know, how much current this thing is
currently using at 9 Volts from the power supply ?
Do you think it will be overunity only,when you put another
2 control coils on it ?
Regards, Stefan.
ronotte
Hi Stefan,
here are the data you requested:
1 - the ECD was connected to my P.S. (decuopled with ferrite ring on wires and 10micofarad poliester capacitor in derivation). The current delivered to ECD during upmentioned tests =  3.2 A @ +9VDC, the light on bulb: ...well not full bright  (not overunity for sure).
2 - With 1 CC only it is of course not possible to obtain max efficiency. Certainly with all the 3 CCs the scenario will be much different. Please consider that the 50% conversion you are seeing has been obtained automatically without any particular freqs adj...just presetted the 3 oscillators and fired them!
3 - Next step will be to get the freq synched along with the 3 CCs on place. For oscillators I'll be using the diagram already posted or something easier as now I've bougth the DDS20 kit (65?) suggested by Rob and found it very easy & useful...
@Rich
1 - Yes you are right as I've had the same intuition! If I just move one of the plates 5-10 cm over (just supporting the smaller Mobius?) ...and spread the coils all over the 3 metal slots provided...it will be just like the 'Open TPU'. But I think that there are still differences...perhaps this design in a certain way is more advanced! (as I'm sure SM newer discovered the Seed) and so lost many clues to refine his ideas.
2 - Please find attached the requested pic. The annular disks have been cutted with Laser according to the template also attached here.
3 - Till a certain limit it's easy to increase the peaks number ...just increase F3 but no more than the allowed intrinsic limit that in my case is about 250 KHz.
4 - Your observation about the peaks that anyway do follow the sine shape is correct. I do also noticed it and it is positive. Now the bigger effort is to search how to get more voltage for the sine itself: now the amplitude is only about 40 V peak to peak (at 9V PS).  Here there's free ground for all to help with ideas!!!  I've noted that whatever design I have made the sine obtained is always at 50 KHz : IT IS CONSTANT.....but for the moment I've always found also that sine amplitude is 40V max as well....
best regards and good luck to all
Roberto
