Rotoverter Initial Idle Results
Started by oouthere, June 15, 2007, 01:05:58 AM
oouthere
Well, I got the initial load results (6 100 watt bulbs) and I'm no where near o/u or even "u".
Rich
ashtweth_nihilisti
Rich, it depends on what application you are trying to utilize.
ATM you have the most efficient .8-1.8 horse power motor in the world, which can idle on the smell of a rag and give you more power on demand (energy savings).
If you wish to extract electrical resonance, then you need an extraction circuit, the latest one reported as working is by an open sourced engineer in France.
This is the NEON switching circuit, and only requires the prime mover to work. circuit cost 19.95$
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
helmut
Quote from: ashtweth_nihilisti on June 24, 2007, 09:40:14 PM
Hello  ashtweth_nihilisti
Can you help out with further information on that circuit.
Perhaps it is compatible with other Projekts on the Board
helmut
wattsup
@ashtweth_nihili
Do you mean as shown on this web page?
http://www.peswiki.com/index.php/Directory:Rotoverter
Under the heading "Power Extraction from Resonance".
If yes, the proponent of this indicates as follows;
"easy to apply to RV alternator as well -> this could be an easier way to get OU at single phase resonance"
Notice he says "single phase resonance" for a single phase alternator, but most alternators, mine included are three phase ac output passing triple rectified bridge to 12vdc. He also used the word "could" which implies also "could not".
@oouthere
Can you re-cap what you did and if you can put up a photo of your set-up?
Under PM fully loaded condition, what is the amperage?
What happens when you remove one bulb at a time from the grid?
Do you know that is many instances, you have to put the start cap back on when the Prime Mover is under load.
Start PM - Start cap on and run cap on
Idle PM - Start cap off and run cap on
Loaded PM - Start cap on and run cap on or off
And at Loaded PM, you may have to play around with the caps to maintain PM  rotation otherwise it will begin to slow down and eventually stop. Also, watch out if the PM starts to heat up.
Here are two photos of some DC-DC tests (non-RV) I had done a little while back. Again here I was losing about .1 volts every 10 minutes. Won't get into this much deeper because it is pointless.
wattsup
ashtweth_nihilisti
Hello stefan and all,
okay maybe best to post this set up in RVreplicaiton yahoo groups then pst the answers back here, they can give more experienced technical advice, that set up can be improved please post you results there ;D
here is the Neon attached
if you find the Rv useful please help by signing a petition for non energy wastage, its as easy as and email and country
http://www.panacea-bocaf.org/RotoVerter.htm
