Regeneration and the Toroidal Power Unit
Started by EMdevices, June 21, 2007, 10:34:43 PM
EMdevices
thank you c0mster,Ã,  I know you're initial take was to use plastic.Ã,  :)
Otto, that's very interesting, I guess non feromagnetic materials can get hot, with supper high frequency and lots of current.
TheOne,Ã,  I agree with you.Ã,  This particular arrangement of the TPU makes a very good case for the Molina Martinez patent.
Oh, by the way,Ã,  Otto, it sounds like you're proposing a ionic tornado, are you?Ã,  Ions are realeased by heat, in vacum tubes, florescent lights, etc.Ã, but not in open air devices at STP (Standard Temperature and Pressure)Ã,  Think about this, what will happen to the "vortes in the center" if there are wires?Ã,  Ã, I would think if it operated along those principles, that the center would be free of random white wires and boxes that can slow down the so called "tornado".Ã,  I know there are exotic theories, but we also have to remember, SM said it used "induction".
TheOne
this is 4 others coil what I put in yellow?
c0mster
To go out on a limb here, I have been studying Hanz Coler?s Stromzeuger, now there is not to much information on this device. I took all the information I could find and wrote it down as a hint sheet. There seems to be similarities to SM , ?rows of copper plates? and ?flat spools?. ?DC current with a AC frequency?. 2 batteries to get the unit started. ?Separation of charge?, ?magnets used in process.? No real circuit or pulse driver just a main coil to ?excite the unit?. ?Current Receiver to thin parallel isolated wires in spool?. ?Single winding halves?.  Just thought I would throw this out as a brain storming exercise. There may be a connection and there may not be but all avenues are worth exploring.
Cam
EMdevices
thank you c0mster,Ã,  all avenues are open.
so so far we've discussed a bit about the most obvious object in the video.Ã,  THE PLATES.
I will try to put together a list of the items I identify in the photos, and we can label them and give them a part number.Ã,  Ã, Then we can just refer to the part number instead of inserting picture after picture.
Once we have our part numbers, and the visual placement from the images, then these can serve us to refute or support theories.Ã,  Ã, Sort of like curve fitting a theory to the "data points".
We will explore and debate each item and theory and how it "curve fits" the evidence.
We should also keep in mind the other configurations of the TPU, but I don't have any good pictures of those.
EM
dutchy1966
Quote from: EMdevices on June 22, 2007, 09:35:51 AM
Hmmm, cant really remmeber that.... have you got a phrase that confirms that?
I agree with the stuff in the center....ther cant be much going on in the center else he wouldn't tell us to put all control electronics there.....
regards
Robert
