Regeneration and the Toroidal Power Unit
Started by EMdevices, June 21, 2007, 10:34:43 PM
Hoppy
There appears to be 9V battery taped to the small TPU. Note how simple this TPU appears to be, no visible electronic circuitry unless its hidden within the coil windings. What are the protrusions at intervals around the top of the toroid?
Thinking from the viewpoint of simplicity, I know that it is possible by using the miniature oscillator circuitry driving a cheap throw-away camera flash powered from a small 1.5V penlight battery to briefly flash a 240V / 100W light bulb. Say SM duplicated these oscillators and fired them on a sequential electronic switch, with each oscillator driving a small coil around the toroid. The oscillators could be imbedded within the coils. If enoough flashes could be produced, then possibly the bulb may appear to be evenly illuminated for a long enough period to demonstrate on video.
I realise this idea sounds a bit crazy but I felt it was worth sharing.
Clive
EMdevices
I did it !!!
I did it !!!
I did it !!!
I'm getting out 3 times the energy I'm putting in !!!
Stay tuned .... all info is comming.
EM
Bruce_TPU
Good Man EM,
Take your time, catch your breath...Document well!
LOL
Happy Days!
Bruce
dutchy1966
Quote from: EMdevices on June 24, 2007, 09:18:04 AM
I did it !!!
I did it !!!
I did it !!!
EM
WHOOHOO  :o........EM we're waiting....... ;D
congrats man!!
Robert
EMdevices
Input power:
12 Volts at 0.05 Amps = 0.6 watts Ã,  Ã, (continuous power)
Output power:
Train of spikes occuring at 10 kHz.
Each spike (see picture: Ã, 50 volts/div, 1 us/div.) Lightbulb when hot has 170 ohms resistance Ã, (when cold only 30 ohms, so don't be fooled)
When integrating across all 10,000 spikes in one second, I get about 3.6 watts:
So
COP = 3.6/0.6 = 6 Ã,
I'll append a video soon.
EM
P.S.Ã,  Previously I thought my spikes were occuring every 5 kHz, but I was wrong.Ã, Ã,  So I get more power output, 6x instead of 3x.Ã, Ã,  Just clearing things up for the doubters.Ã,  :)
