Regeneration and the Toroidal Power Unit
Started by EMdevices, June 21, 2007, 10:34:43 PM
CTG Labs
Hi EM,
Could I suggest, instead of getting a 4 watt resistor, instead use a 2 watt resistor.  If need you do have 3.6 watts output, and you can only dissipate 2 watts it should burn out if you have more power, on the other hand, if it doesn't burn out or get hot, then you can know the power is not that high.
D.
EMdevices
Guys, I have no doubts this thing outputs about 3 watts.
That lightbulb gets hot and I can't hold it, also my carpet starts to smell after a while, it's being burned.
EM
turbo
okay, i will replicate this imediatly.
Marco.
CTG Labs
Hi EM,
I assume you have added a resistor to that circuit (after the main coil) because if you connect that to a higher current supply (with only 45 turns), other than a little solar panel, its almost a short!  When I build one before I got 30-50v spikes, but I wasn't looking for extra energy at the time!
D.
dutchy1966
Testing for OU by burning your carpet???  Different..... ;D
