Magnetic shadow casting
Started by dutchy1966, June 25, 2007, 03:09:05 PM
dutchy1966
Hi everyone,
First I'd like to remind you all of this phrase from SM:
Has anyone ever read the reports about our experiments with what was called,ââ,¬Â­ ââ,¬Â¬the magnetic shadow casting materialââ,¬Â­?
ââ,¬Â¬Those experiments tie in with to our development of the power unit.
As you might have found it is really hard to find anything about it. Today I found a somewhat strange patent. (attached)
It deals with magetic shadow imaging/casting. It deals with magnetic fields,coils in spiral and circle setup,perpendicular plane fields,RF amplifiers,eddy currents cancelling ferromagnetic effects etc. In short a lot of stuff that apparently has something to do with the tpu. The weird thing is I cant find it in the american patent systems, only in the european one.
BUT, it is missing all its pictures. The patent says in the beginning "no drawings" but then again in the text refers to the pictures all the time.....???
THEN, look at the company name this patent is registered to......No it's not UEC.....but is this name just coincidental????
So my question is, does it have a relation with SM or the TPU and is ther something in there SM is trying to point us to?  Like eddy currents cancelling electromagnetic effects?
Hope someone can clear this up.....
regards,
Robertââ,¬Â­
Bruce_TPU
dutchy1966
Bruce hi,
Keep getting a server error.....have you got the patent?
Can you be so kind to upload it here?
thanx!
Robert
Bruce_TPU
zapnic
