The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
z_p_e
Quote from: EMdevices on July 02, 2007, 11:17:16 PM
thanks for the layer description Brnbrade, that helps.
I started winding but I missed an aluminum layer, so I got to take it apart and fix it.
Darren, he says the trick is in how you start it.  I thought about this and it could be quite interesting.  I bet we can do a model of this in PSpice, etc..
EM
Perhaps it could be SPICEd EM, but I still have no idea of what the circuit is. I must be dumb because I have not seen a diagram showing all the components.
Could you or someone else be so kind to draw one up? Sorry for my incompetance.
The question remains, why doesn't he post a simple diagram if he wants everyone to get online with him? Why keep everyone guessing?...and it does seem that people are still guessing.
Darren
Mannix
Quote from: btentzer on July 02, 2007, 09:58:52 PM
@ All
Funny thing, I remember SM telling all of us to use mosfets to reproduce waves as if they were mini tube amps.  I have said that about, Oh, 20 times or so.  But this is coincidence I am sure...  ;)
Sorry Bruce
At no time did Steven ever say to all of any body to use mosfets...he only ever said to me that  he used them after using tubes for initial tuning. That is the information ,in context,that I shared.
I know that you are excited But
please do not mis quote..and re interperet...this will be hard enough as it is.
brnbrade
you are going to have to give complete disclosure ..these people really want to duplicate what you have .....lots more pictures with the light on from lots of angles should keep them happy for a while
It looks so simple that any body could make it with out having to learn anything ...unlike a TPU! you the man..Im off to buy a recepie for pie...just in case!
thanks.
Lindsay Mannix
Bruce_TPU
Quote from: Mannix on July 03, 2007, 12:46:21 AM
@ All
Sorry Bruce
thanks.
Lindsay Mannix
@ Mannix
Yes I know that SM said to start with TUBES first.  How much of that do you see happening, besides yourself??
So, what do we have...  We have Mosfets and drivers being used in the ECD, unless I read my circuit wrong tonight and I am soldering up (actually my partner! LOL ) the pieces for nothing.  SO, let me make this very clear.  WE ARE using Mosfet and SM said:
"MOSFETS are better you know if you wanted to make an amplifier that behaved as though it was a tube amp but in a smaller size."
So, let me reiterate my point from earlier:  We need to incorporate what SM has said into what we are doing.  How?  Look at the wave that a tube amp puts out and look at our square wave.  Do you see any difference?  Well of course.  Why?  Because one is slightly rounded.  What are the other differences?  There are many..
@ EVERYONE ELSE
I have put together on the first post what is needed to replicate to the best of my ability.  If you can answer the questions I put on there, that would be great.  If you can draw pretty schematic that would be great, and I will gladly post it!
Happy, Happy Days!  (But hearing they hear not!  We need ears to hear and eyes to see)
Bruce
z_p_e
Lindsay wrote:
QuoteI know that you are excited But
Exactly.
btw Bruce, which one is slightly rounded then, and how is that significant to the TPU and the ECD?
Darren
z_p_e
brnbade,
I'm not sure if you'll respond to any of my posts, and I'm sure you have 100's of PM's to attend to, but I wanted to ask just one simple and direct question.
I am really only interested in (and the only one that matters) brnbade's response to this, so hang back guys if that's ok.
I have no intention of trying to chase you away or discourage you, I'd just like to know the following:
WHY did you post about your device?
Eu n?o tenho nenhuma inten??o de tentar persegui-lo afastado ou para desanim?-lo, eu gostaria apenas a sei o seguinte:
Por que voc? escreveu sobre seu dispositivo?
Darren
