The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
wattsup
@all
I did a few phorensic dimensional measurements - CSI style.
Took a reference off the transitor on Trial #5 - center circle being 3/4".
Came up the the following dimensions for the coils.
May not be totally exact but it's the best one can do with what is given.
MeggerMan
Quote from: jacob on July 03, 2007, 10:20:06 AM
Quote from: z_p_e on July 02, 2007, 10:59:40 PM
It would not be too difficult to power a 12V, 50W bulb for a few minutes from 2 AA batteries with the right circuit. Keep that in mind folks.
Darren
I need your help here. I have no idea how this would be possible. Because it would imply pulling upward of 10-15 amps from those small batteries and maintaining that draw for a few minutes. Plus, let's keep in mind that there is no high speed switching component being used here. Can you please explain how it can be done. Thanks!
@All,
So just how much power can you pull out of two AA batteries?
I have just completed a test using various NiMH batteries as the other zinc carbon batteries I have are nearly flat, perhaps someone can test these:
Cell = 1 x AA size GP 2700 mAh 1.2V
Test load = 0.8 Ohm resistor (3 x 2.2R in parallel)
Output = 1.25A @ 1V
I tried heavier loads but the voltage drops further, so 1.25 watts seems about the limit.
2 x AA cells should provide about 2.5 watts but this may cause the batteries to explode because of the relatively high current draw.
So Darren, hopefully you are correct, with the right circuit you CAN light a 24V car headlamp halogen bulb. The right circuit being a TPU!
Rob Ã,
jacob
Rob,
Thanks for the info. I agree with you that drawing that much current from the cells would be dangerous. Actually, you probably noticed some overheating during testing didn't you?
Quote from: Earl on July 03, 2007, 11:59:17 AM
Rich, no power should be input.  It is the Creator's aether which is the input power.
Thanks for the quote Earl. I just love it when I hear stuff like that!
Jacob
Bruce_TPU
@ Earl
@ Wattsup
I have updated page 1 with your information.  Thank you both.
@ALL
I will no longer post any more "Theories" of operation on page 1.  Only build information to assist replication.
Happy Days!  :)
Bruce
chrisC
Quote from: btentzer on July 03, 2007, 02:17:15 PM
@ALL
Happy Days!  :)
Bruce
Bruce:
Thank you for the good job in putting the build info. together for easy access. I also want to thank you for your time, channeling excitement into this Forum and sometimes, even your out of this world suggestions.
However, some of us would rather not hear of wildly speculative theories unless there really is really good grounds for suggesting it. Out of context, these things are very confusing. What we need is FOCUS and Quality Test results which are reproducible and hopefully quite explainable when the code is cracked!
Nevertheless, great job and well done! Thanks.
chrisC
