The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
MeggerMan
@Stefan,
I think if you had check the voltage across the terminals of the cell then I estimate the voltage would have been less than 50mV.
I think that the older style NiCd will give a higher current than the current NiMh but I think Brnbrade was using zinc carbon.
@Jacob,
I had the cell connected for just seconds in case it blew apart.
@All
Progress:
1. 12mm OD x 225mm aluminum tube.
2. 1 layer of PVC tape.
3. Primary 0.56mm enamell coated wire, 320 turns.
4. 1 layer of pvc tape.
5. Around 800mm length of foil wrapped around the primary.
6. 1 layer of PCV tape.
7. 2700mm of 2.5 sq.mm pvc insulated wire, 40 turns
8. Testing starts tomorrow night - I'll post the results.
Note: Using the cordless drill for the primary cut down the winding to about 2 minutes per tube. You just need a drill that will accept a 12mm bit.
Rob
z_p_e
Earl,
I already saw your drawing yesterday.
If your drawing is complete and as per brnbade's build, then why are there question marks and unconnected parts on it  ??? I wouldn't be asking if one of the builders could kindly produce a drawing, if one already existed that was complete.
If we go by the 4 variations that have been identified, it looks like you have attempted to draw #1....Coils and battery.
So what's left to be determined, is where the battery is connected, and if there are any additional connections to terminals 1 and 3. Does anyone know?
Darren
Bruce_TPU
Quote from: z_p_e on July 03, 2007, 06:47:03 PM
Earl,
Darren
Darren
There are only four options.  Pick one!  LOL  an experimenter can try each one.  We are not "blueprint" bound.  Sheeesh..Just build it for yourself, or hold your pipes!  (every pun intended) Someone soon will reproduce hopefully and draw you a "proper" schematic ready for the "simulator".. ;D
gn0stik
Well, I suppose the good news is, you can recycle that into a tesla coil if it doesn't work.
That'd be sweet.
@brnbrade, please confirm whether or not Earl's diagram is correct. Also if you have any details to add about where the bat is connected that would be nice. Also what type of radio did you use when you powered your coil with a radio? And was the output speaker output or headphone output.
Please, NOBODY ELSE ANSWER, I am not interested in spokesperson's opinions.
If you want to answer in portugese or spanish that's fine, I can translate portugese. And I can read spanish.
Rich
z_p_e
Quote from: btentzer on July 03, 2007, 08:14:46 PM
Earl,
Darren
Darren
You're completely missing the point Bruce.
Also, I have no intention on simulating the Cook patent at this point.
If and when brnbade produces a complete schematic (pick any version), then I'll decide whether to put any further time into it.
Until then, IMO brnbade has shown us nothing more than the already existing and previously discussed (months ago) Cook patent.
Perhaps you could do that mind-meld thing again with him, and tell us where he has the battery connected  ;D
Darren
