The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
hartiberlin
Quote from: BEP on July 03, 2007, 10:40:31 PM
Quote from: hartiberlin on July 03, 2007, 10:28:36 PM
@BEP,
what is Al varnish ?
Aluminum or Aluminium varnish is a protective coating applied to metals. You see varnish of another sort on magnet wire - very thin almost plastic like coating.
Al varnish is made to protect Aluminum and prevent oxidation. I suspect it causes oxidation to form initially - as part of that process.
Are there small Al particles or Aluminium powder mixed into the varnish or why is it called this way ?
BEP
The label is old but it is clear it has no form of Aluminum in it.
I just realized something folks. Look carefully at the photo above that EM posted. Look at the coil connections!. It is not wired dual parallel. It is wired in quadrature feedback mode. All four coils are wired as a ring not as deduced on the build page!
I know the patent shows it the other way but how many times have you run into a patent that was 100% correct. Intentional flaws are common.
hartiberlin
Quote from: EMdevices on July 03, 2007, 10:54:34 PM
Here is my coil, if you're curious.
Hi EM,
nice setup,
so you are only getting 60 Hz induction from the grid or what ?
Do you also have iron rods ?
Did you try to premagnetize the Rods into the BH regime, where they
begin to toggle their domains for the Barkhausen noise ?
( For this you must probably bring some magnets in a destinct distance to the rods
and leave them there....)
It also depends much probably, what kind of iron rod one is
using to get a maximum Barkhausen noise level out of the rods.
@All,
I think I will leave this topic in the Special coil-magnet setups
category,cause I really don?t see any simularities with the TPU over here.
In the TPU you have collector coils at 90 degrees, over here not at all.
If the Brnbrade  thing really works, it is my guess it is much more related to
an selflooped and amplified Barkhausen energy extractor.
Regards, Stefan.
hartiberlin
Quote from: BEP on July 03, 2007, 11:03:42 PM
Then why is it called AL Varnish ?
Is it just a standard nonconductive varnish ??
Exactly, I wonder myself, what would be the right setup ?
This way as EM did it or turn one rod 180 around and have it then in parallel with the same
wire turn directions ?
What will amplify a looped pulse better  ?
EMdevices
I tried lots of magnet setups Stefan. Ã, I'm getting 60 Hz from the grid. Ã, I suspect brnbrade is getting the same. Ã, Too bad he does not have a scope. Ã,
There might be some merit to this setup, but it's definitely not related to the TPU Ã, :) Ã,  Ã, So good call Stefan, just leave it here. Ã,  I'm sure TPU related stuff is all over the forums anyway, we'll just have to hunt and gather relevant info.
EM
