The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
bob.rennips
QuoteMaybe Brnbrade had the coupling via his magnets at the left side ?
I would agree one of the pictures has what looks like a small 1inch magnet to the left of the coils.
weri812
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
z_p_e
Quote from: wattsup on July 04, 2007, 09:23:26 AM
Besides all this noise, noise , nosie.
You're absolutely right wattsup. The noise doesn't belong here...apologies.
I'll be posting something important in the TPU's "A Place for Debate" thread.
Regards,
Darren
Bruce_TPU
Good morning, All!
I have place Bob.R's diagram on page 1, post 1.
Excellent Work Bob!
All builders:
Please use aluminum varnish only.  Let's find it online and post a source.  I will add the source to page 1.  Or multi.  1 in US one in EU.
So if you do not use the varnish.  And if you do not wrap on aluminum tube.  Then my guess is it will not work.  The Iron (rebar was a good idea) goes into the alum tubing.  It can probably be adjusted to "tune" as well.  At least an avenue of experimentation.
For more info why the alum varnish is so important, please read BEP from yesterday.
Also it is what our young friend wrote to me he was using.  Just because it is not readily available does not mean we should not use it.  So I suggest slowing down, getting all of our parts.  Matching wire sizes and then replicating.
Happy 4th of July!!
Bruce
wattsup
@bob.rennips
Thanks for your info, but geez, if you look at Brnbrade's unit, mine is exactly the same, same winding directions and same connection points. Also on Farlands patent, his Figure 2 is identical to mine. But, I will try the other way when I get home as with other configurations, since Brnbrade has not indicated the cap values, etc. I'd like to know what type of capacitor he is using in Trail #1 and #2, please.
As for the core, in the patent Farland states " The iron core A may be solid bar or a bundle of iron wire, the latter giving higher tension to the current with equal length and fineness of wire.
Also, would you agree that when Farland refers to the Primary, he means our secondary and vise versa.
Lastly, for start-up Farland refers to the possibility of using a magnet, an electro magnet or by winding a second Primary on the coils. This sounds like a good idea and can be done easilly. I think this is what Brnbrade has highlighted in his reply #265 on page 27.
