The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
pese
@all
I have seen this (Mc Farland)-patent already years and somewhere with myself texts in addition abgepeichert. Nevertheless, in my brain I still have
stored, that the iron core also of many wires can exist. (what will work usually also better)
Moreover further a reel 23 turns and second had less windings (I think it 15 were).
For me it is not explicable
why in the patent of thousand feed drahtl?nge the speech is and no information was done
Gustav Pese
http://ch.to/FE
Bruce_TPU
@ Jason & Earl
Yes, Earl's drawing is good, but a few things need to be added.  The thin 1000 wrap primary is ontop of the larger 12 awg. solid wrapped wire, which is wrapped first, and then the other wrapped over it.
Also, air core as I have said.  And do not forget the large magnet in the prescense of the coil.
and lastly do not forget the oscillations from the stereo with Identical signals/different source opposing one another, with one signal slightly out of phase.  (Whatever degree out of phase to produce stereo music.  ANOTHER CLUE answered OF SM's.  How many times does he mention "STEREO".  LOL  I missed it until JUST NOW!!  HA!
Blessings,
Bruce  :)
Earl
Hi Jason,
From the patent text, it is clear that the more you break the core up into smaller and thiner wires, the better.  It appears to me that a massive, solid core is the exact opposite of what you want to do:  many fine iron wires as core.  Fence wire maybe.
Regards, Earl
Quote from: Jdo300 on July 01, 2007, 02:06:57 PM
Hi Earl,
My setup only has steel cores on it. 1018 if I remember right. The coes are 2" in diameter so I never tried to find magnets that big to replace them with  :D.
God Bless, Jason O
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
turbo
Quote from: Earl on July 01, 2007, 12:43:33 PM
Hi Marco,
that is interesting.  Will see if Brnbrade or others can get it to work.  My image was drawn by looking at Brnbrade's photos, so he is definitely having some results.  One puzzling thing, it looks like he only has a voltmeter as load and that is not all that much to keep the action going.  The patent says the output must always be loaded after a kick start.
Also his first circuit presented is completely different than the present one.
Did you try both ferric and magnet cores?
Regards, Earl
Hi,
i tried the "iron rod"
and i tried many times to start it by sweeping it with a magnet and aplying pulses to it but it never continue to run.
Marco
gn0stik
Nice transformers.
Hope you prove me wrong, but.... I have a feeling I could pull a couple of these from a pc power supply and do the same thing.
without current measurements, we can assume nothing.
It is wired up like a magnetic amplifier, interestingly enough. I have some theories about those things, and they do keep popping up, the vta, otto's research, etc.
Hope theres more to it, and the tale will be told by the amp measurements.
BTW, why not rectify and measure amps out on that analog meter? It has DC amps on it.
Regards,
Rich
