The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
gyulasun
BEP
It is a great read!
At a minimum you'll see the real meaning of terms used in the Cook patent.
wattsup
@BEP
Yep, you were probably reading the same time as me. A definite must have in any OUers, grab bag.
The thing though is that nothing there is really discussing any OU potential, and all my tests so far (Build 2.0) have not given anything at all.
Funny, in the book he talks alot about using wire cores and my first build using a wire core gave me some of the best results.
But when you think of it, regardless of how you connect the coils, if you have power on two ends of the primaries and the load off the other sides, in essence, the primary will bypass the secondary as the path of least resistance to the load. Or am I regressing. My primary is 0.3 ohm and the secondariy is 8.2 ohms.
Now if I was working on the Mythbusters Show, after three builds, and testing all of Brnbrades Trials, expect the one with the small brown capacitor, but I tried about 30 different types, I would have to say that this Myth is Busted.
Whatever Brnbrade did with his coils to show the results he did, I am now very convinced that he first set the meter callibration screw way above the zero point, then did his connections and showed his results.
So either he is a total ignoramus in the way he used his meter or he just pulled a fast one.
My builds are totally as per his instructions and he has never come back to this thread for any other clarifications, so at this stage of the CBC saga, Brnbrade is in the bottom heap of the crap pile. Sorry but that's why people replicate. To see if others are saying the truth or if they are bullshitting us. Let the results speak for themselves.
I'm sure Brnbrade knew it would eventually come to this and that is why he never came back. He wants to forget this ever happened and he surely did not think someone would build three CBC's to find out. Well i'ts done.
This case is closed.
So now that I have 4 solid iron core CBC sections, maybe I can build an Erfinder system placing each coil at 90 degrees. lol
BEP
Agreed.
It was definitely a learning experience. I was pretty sure he was onto something until he suddenly switched tracks. The use of Aluminum, some Al varnish actually containing copper oxide with no AL (the stuff that looks dark blue when dry). His results that started to sound like an earlier project of mine. I was chomping at the bit to pat the man on the back.
The good part, for me, was all my trials with figuring what he might have, led to a clearer understanding of what went on my bench before he appeared.
And now we have a Rosetta Stone for 19th century patents!
Primary = fundamental frequency
Secondary = first even harmonic
Tertiary = first odd harmonic above fundamental
Some coils are iron wire
Windings of that era had a thick insulative coating vs. enamel today.
If an Al or brass sleeve of coil covering is mentioned it should be assumed it has a longitudinal slot along the entire length. If AL without a slot the magnetic field from the coil is concentrated inward because of a Halbach like effect.
The first oscillators were longggg before Tesla!
Probably a few more I can't think of right now.
That and the understanding of magnetism hasn't improved much since the early 1800's  :'(
scotty1
Hi guy's...I see you found the book....
Look in that book and see how the Earth's field is described, and how it would effect science if it were correct.
The truth is that all the magnetic theories of today are wrong, and it is because of the mathematics they use to describe electrons. This maths does not allow them a complete picture.
Erfinder refuses to see the truth too...even after i corrected his drawings....he went and changed them, and then told people off for changing HIS drawings. ???
If the scientists would admit what they know to be true, what their theories themselves predict, then we could all get on with our work in a new light.
To electrical engineers the positive electricity is everything...but to the physics guy, he only cares about the electrons.
Do they really know how the current is running in a wire? Which way it is going and what makes it?
I tell you the truth...BEMF or reverse current spikes have nothing to do with a collapsing field in the coil.
Scotty
leedskalnin.com
