The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
bob.rennips
Well done brnbrade. The bulb brightness looks great -definately something happening here.
As requested here is a document about recitification for amp measurement.
http://www.faqs.org/docs/electric/Semi/SEMI_3.html
See about half way down - "full wave rectifying circuit" (bridge design)
You need 4 diodes for best result.
Or just use one diode, and double the measurement - this assumes the AC averages out to be symetrical over time.
The only item I'm unsure about is where the stereo connections are made.
Are you connecting the two positives but not the common negative ?
brnbrade
EMdevices
brnbrade, Ã, why do you mention a MOSFET? Ã,
Do you have a MOSFET in the circuit? Ã,
I thought it was a simple 2 transformer setup with a batteri and a capacitor, which it appears you don't use any longer.
You can draw a schematic on paper and take a picture, Ã, it doesn't have to be on a computer. Ã, :)
EM
hartiberlin
Quote from: brnbrade on July 01, 2007, 10:03:24 PM
I need scheme of the mosfets for drain the amps.
Hi ,
what should the MOSFET circuit exactly do ?
Draining which amps ?
Or controlling the draining of the amps  from your 2 batteries ?
Please explain and also explain more your circuit.
Many thanks.
Bruce_TPU
@ Brnbrade
Hang in there you are doing great!!  :D
@ Everyone
I did find out that the volume on the radio was set at 30%
It looks to me that the coils are wound over a plastic air core and then a nail is inserted into the center of each.  Is this correct brnbrade?
Also, I think there is only the large speaker magnet that is seen.  This is what he said last time on another thread.  Is the large magnet the only one brnbrade?
Happy Days!  :)
Bruce
