The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
Earl
Hi Brnbrade,
Can you please provide me with explanations for the two questions in the attached image?
Pode voc? por favor fornecer-me com as explana??es para as duas perguntas na imagem unida?
Please can you take another photo showing all wires when the lamp is shining brightly?
Por favor pode voc? fazer exame de uma outra foto que mostra todos os fios quando a l?mpada est? brilhando brilhantemente?
Obrigado muito muito.
at? logo,
Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
Bruce_TPU
@ Earl
Nice drawing, we will see what he says
@ALL
I am now convinced that EM IS CORRECT.  The language barrier has caused brnbrade to call the bottom wire primary and the top wire secondary.
When I blow up the photo, I can clearly see that the thicker RED wire is ON THE TOP of each coil, and NOT the bottom!
Cheers,
Bruce
Bruce_TPU
@ Earl
The core is iron.
What the wire is wrapped on is AL.
The ONLY magnet is the large round speaker magnet seen behind the coils.  I asked him this and posted his answer yesterday.
If you could correct the drawing in that regard, thank you.  This way we are not asking the same questions again.  :)
Please REFER to Patent picture he posted with the arrows!!  Thanks.
Bruce
Bruce_TPU
@ Earl,
You are also missing the wires from the stereo.  In the picture these are the things that look like jumper cables, hooked to the bulb.
@All
Knowing the larger wire is on the top, is troubling, even though the input is DC.  And also I think that we need to know where the two YELLOW wires go to.  A picture of the radio and ALL the wires would be a help in believablity.  Also, the zero reading voltmeter is a concern.   :-\
Cheers,
Bruce
Bruce_TPU
Quote from: btentzer on July 02, 2007, 09:23:37 AM
@ Earl,
@All
Cheers,
Bruce
