Thanks to ALL for your help!!
Talking about phase...
Started by bob.rennips, July 01, 2007, 08:16:56 PM
Bruce_TPU
A heartfelt thank you, Bob.
Your concern for those guys dabbling where they ought not tread, just shows what kind of fabric and character you are made of.  And thank you for your continued availability.
High regards,
Bruce
starcruiser
Same here Bob, your contributions are appreciated as well as your offer.
Regards,
Carl
starcruiser
@Super God,
I will post you something on the Blocking Oscillator that may help a bit later, I am still working and need to complete a project.
But in simple terms the blocking oscillator blocks the transistors conduction due to negative biasing from the coils wave. The oscillator can produce squarewave like pulse of short duration, this is depending on how it is designed/built.
I found the links I provided interesting due to the use in older TV's and the SM story about the exploding/Imploding GE TV.
Regards,
Carl
HumblePie
Please do at least point to any 'additional' information you may have on the Blocking Oscillator, cuz its high on my need to know list!  I will post back what I learn.  Thank you all very much for sharing.  Humble
gn0stik
Anyone here had any luck working with this design?
Rich
