Talking about phase...
Started by bob.rennips, July 01, 2007, 08:16:56 PM
HumblePie
Hmmm.     About Phase means about phase... and coil config's that relate to phase... and pulsing strategy.
Bob. B's words here and on page 67 of Succ'TPU-Replicat' thread were very carefully written so read them well.
Please post photos here of things created from his advice.  Nothing not stemming from his words.  You've all suffered reading bla bla in other threads to understand why.
This is not Poker, this is about mentoring each other.  If someone takes time to PM you, help them.  If they need to 'step off', tell them.  They are asking for your help offline so as not to mess up and dilute these threads!  Point to the info if it is in thread somewhere when you speak about it.
Show how you accomplish phase control, show your edge speeds, show your waveforms.  Briefly share results here born out of Bob B's advice so Bob will come and see how the garden is growing.  If you've read his words you should now be 100% motivated to begin building a coil... any coil.  If he comes back here and sees 250 pages of bla bla lost sheep, this may be it folks!   Show the fruit!
Grumpy
Rich:
you are correct - Bob did state FET's.
Will edit my post, but I do not see why a lot of power should be required.  Should be able to run it off a battery.  Maybe Bob is running a house from it.
wcernuska:
point taken.  Let's keep this thread clean.
All:
I'm going to rewind my primaries and will take pictures this time.
        -Frank Edwards
Bob Boyce
@all
I'm sorry that I have not been on. I was staying with my daughter at the hospital as she was going through a surgery, and no internet there. It will take me a day or two to rest up, go through the posts, and post responses.
Bob Boyce
Bruce_TPU
Hi Bob,
I hope that all is well with your daughter.  I too have a 5yr old.  The joy of my life.  I will keep ya'll in my prayers.
Thank you again for your time.
Warm regards,
Bruce
gn0stik
Quote from: Bob Boyce on July 10, 2007, 11:15:10 PM
@all
Bob Boyce
No problem at all Bob, health and family first man. Time will come. Till then do what you have to.
Regards,
Rich
@Grumpy, NP man.
@all, are you guys using cores or a wire core like SM? If you are using cores like Bob's, where are you getting them?
Regards,
Rich
