Getting Through Stickey Spots?
Started by Sanity101, July 02, 2007, 02:12:52 AM
Sanity101
Ive been doing allot of research and think but am not sure on how to get around magnetic stickey spots everyones been having.
In a hard drive there is magnetic shielding this shielding I believe is called MU Metal. I think it's there that way the magnet in the drive dosent F up the electronics. On all of the videos Ive seen the shielding has been added to the magnets on the rotor.  But what if you added it to the fixed magnet? That way it's only pulling one direction.
What do you guys think?
Freezer
Theres only so much you can do with it, but try different configurations out.  No one here has the answer otherwise we'd be cashing in :D  I was pondering the idea of trying bismuth discs into the configuration.  Bismuth so I've read can be heated and poured, to make your own custom shapes.  I've just been thinking lately that a magnet motor might take metals and other materials besides just magnets.
Theres also another problem I've run into many configs.  After about 120 degrees the magnetic field starts weaken.  I think perhaps a device divided into sections at a minimum distance from each other so as they wont interact and cause ill effects.
magnusx
If you want to block magnetic fields there's also a new material I found via this forum   - graphite made by chemical Vapour deposition. I can't find the site page now - i think it was Scitoys . . . but the stuff is so diamagnetic that it will float above both N and S poles and its available online relatively cheap unlike bismuth.
OTOH, I don't know wether it will really make a monopole just by blocking the field of one pole - try it and let us know!
z_p_e
Guys,
Magnetic shielding (a poorly understood misnomer in itself) has been tried by dozens of people in dozens of ways. If it was easy, it would have been done by now I would think.
But try it anyway. See the effects.
Regards,
Darren
JamesThomas
Check this link out. It's a material called Giron that has some very interesting properties.
http://www.lessemf.com/mag-shld.html
It's $35 for a 2'X1' piece. It can be cut. A bit costly, yet seems like a very useful addition to ones magnetism experimentation lab.
j
We are not what we believe ourselves to be.
