Open Letter to Steorn
Started by hartiberlin, July 06, 2007, 07:44:11 PM
ltseung888
(The same information was posted at the Steorn.com/forum in the thread 'technical suggestions for Steorn')
Steorn gave the explanation of the failed demonstration as bearing failures:  FIVE bearing failures from three units when transferred to the final Demo unit.
Can we believe such an explanation?
Wang met similar experience with his device early on.  Once the axle starts to spin, the spinning can keep accelerating. (Remember his four-legged stool experiment?)  The generated output energy has nowhere to go and built up as heat.  That could easily crack the bearings.  Thus bearing failures are possible explanations.
Wang's device has three solutions on this:
(1) He used another of his inventions - heat resistant bearings.  The bearing case has slits that allow room for expansion.
(2) He used his double coupling system to limit the maximum rate of rotation.
(3) He drew energy out via the rotating central shaft.
Steorn and other Over Unity developers should not lose heart.  You are making progress but you have not reached the final stage yet.  (If you have, you might get the same treatment as Wang in China.)
Lawrence Tseung
Cracked Bearings Lead Out the Wang experience and solutions
dimitri
Tseung,
Did Wang encounter the 'silly-duck" effect with expanding bearings when humidity would cause non-linear expansion due to partial cooling of the device?
How did Wang solve this problem?
ltseung888
Quote from: dimitri on July 23, 2007, 01:51:34 AM
Tseung,
From the previous post:
dimitri
dimitri
Well I assume Steorn's chief executive officer must have returned from a well deserved holiday by now. The new magnets have arrived, new bearings made of 8Kh4V9F2-Sh have arrived, colder lamps have been installed and the world is ready for a revolution.
So when is the demonstration planned?
