Thanks to ALL for your help!!
TPU: End Game...
Started by tao, July 09, 2007, 03:11:13 PM
innovation_station
tao
like your thred and all your posts i have a question or 2
TUBES  i think tubes as well  but what kind of tubes are you thinking of i am currently looking for tubes i found a huge supply of all tubes but i dont know anything about tubes can you offer specs of tubes and reasons why you think those tubes would best suit the tpu in your opinion
thanks agin tao
william
tao
Quote from: Grumpy on July 16, 2007, 07:31:18 PM
Kicks - explained numerous times.  It will make sense once you have a RMF - which is created by kicks - at least that is one way to do it.  "Kick" is an old term for pulse - nothing more - nothing less.  When created by a coil (magnetic field collapse) - the term "inductive kick" applies - not to be confused with a pulse from a capacitor which would not be inductive.
The term KICK, when used in all of our contexts when refering to the TPU, was originally coined by Steven Mark. Steven clearly states that the KICK he is talking about is the HV that is generated BEFORE current starts flowing in ANY conductor, it is all based on electron gas relaxation times (I made a PDF will all these last year).
So, the PRIMARY way that we should be generating KICKs is to only use the HV spike that appears BEFORE the current flows in our control coils, that is, if we TRULY want to adhere to what Steven Mark said.
gn0stik
Quote from: innovation_station on July 16, 2007, 11:17:38 PM
tao
thanks agin tao
william
I get the strange feeling you are interested in tubes?
innovation_station
yes tubes
i think stevens words should be followed exactaly and he said TUBES so i will work with tubes why?
because it is easyest to start there there many many reasons to use tubes to test then ss in the finished ring after you have the exact freqs for the ring using tubes plus how many people are using tubes and how many people have a working tpu not enough start where steven said to start that is my aproch
ist
any help with tubes would be great thanks for your time
tao
I would like to bring to you all a PERFECT explanation/example of where the preferred KICK that Steven Mark talks about comes from. This would be the KICK that appears BEFORE current flows in a conductive coil/wire...
Below is a VERY GOOD, and MUCH SLEPT ON POST from aether22, posted on another forum.. I might just post this separately in another thread too, as the idea is viable.
Pay attention ;)
aether22:
"I am a major proponent of the aether, though I didn't like it to begin with it just makes far too much sense.
What is odd is I'm going to present a Free Energy device that does not use the aether in any way.
In part that's why I'm presenting it here, not sure I need this distraction, but it's so straight forward.
It's the super charging effect, connect a decent voltage to a long piece of wire and current flows, if it is an open circuit it will take a while before it knows this and so it will send current through anyway charging it to a high voltage, it's the electrical analog of the verified OU water hammer effect in pipes, now if we take the speed of light in a vacuum 299,792,458 meters a second (in reality it will be slower than that which is good) and suppose a 200 meter transmission like, then double it to 400m because the wave gets to the end and must reflect, so that gives us 749,481 but we need some off time, so assume a 50% duty cycle, we have 374,740 hz, quite reasonable.
Now what happens where all those electrons, amps and amps worth squeeze themselves into a piece of wire? Well you get a crazy high voltage.
Maybe even high enough to release the electrons as effectively beta radiation.
At any rate metals near it will be charged, now what does this sound like to you?
Tesla, Ed Gray.
We know the effect works, it occurs in long transmission lines (it happens every time, and it's killed people), there is nothing to doubt, and the math works out.
It's only an issue on engineering it and making it practical, and unlike the mysterious forces of the aether we can calculate this one before we begin.
Now I am in favor of doing this with a long line as that simplifies the switching we can make a compact long transmission line by making the type of coil Hooper (motional magnetic field guy) made, where we fold a wire back on it's self, by doing this we get a compact transmission line without the inductance of a coil (a normal coil will slow the all important rise time), a normal bucking bifilar coil won't work as the impulse will transfer inductively and will appear superluminal as it won't travel through the wire, but the Hooper coil or tightly wound bucking parallel caduceus (in other words a normal caduceus) will have both types of inductances cancel.  (note: the caduceus coil must be single layer, note2: interestingly induction will still take place, only it will be weak microwave frequency oscillations)
Of course any dual channel scope can easily measure the effectiveness of a delay line section.
It would be possible to do this with mechanical switching if you had a delay line of over 200 meters, although it would be difficult.
You could tap the power in 2 ways, one is by having the charges spray or arc to another electrode, the other obviously is by capacitive induction, in either case you going to want to surround it by an electrode as Ed Gray uses, not sure why perforation is required/preferred.
This is a pretty straight forward Free Energy device, we can calculate it, work it out, run easy tests with oscilloscopes, calculate what kind of voltage we will be dealing with, it's not the mysterious type of Free Energy machine, it's a totally reliable mathematically certain proven Free Energy machine.
We can either run it as stated above or instead use the principle of opening a closed circuit, though the frequency will need to be twice as high.
One thing not noted above is that once charged, unless it sprays all of it's charges away the transmission line might need to be discharged, indeed in we want we may opt not to use another electrode and merely discharge the high voltage on the transmission line.
This is also better in some ways than my favorite of gaining Free Energy from the aether as this is a single effect, it can't be misused.
I recommend anyone not sure what to do should work on this, it's a Free Energy effect like no other, we know it's been done before (Tesla, Ed Gray, Swiss ML) and we can calculate it, it's success isn't Dependant on unknowns. (the effect is also clearly present every time you flick a light switch and hear speakers pop, it happens in transmission lines, and best of all it happens every single time)
So if you don't know what to do, work on this.
Another thing, this effect can also be used to create a unidirectional propulsive force by turning 2 electromagnets on and off in the right way, this has already been patented.
Turn on coil 1 and it produces a magnetic field, turn coil 2 on and it is immediately attracted/repelled by the magnetic field of 1, however coil 1 does not instantaneously know that 2 has turned on and so for a moment 2 ir pushed while 1 is not, now once the field from 2 reaches 1, turn it off, it will still take coil 2 some time before it detects detects the field from 1 has changed and it will continue to experience force, if you do it right 1 need not have felt 2 at all.
IF infact coil 1 does immediately react to coil 2 being turned on then that is a superluminal reaction, pretty cool (and generally considered impossible), otherwise the only other way this could fail to create a unidirectional force is if coil 1 which no longer has and current flowing through it (it's open circuit) feels a force even though it no longer has a current passing through it and is no longer creating a magnetic field which is kinda crazy. (Indeed if you had a huge coil in space, you could turn the coil off, turn it into scrap and then have a force placed on it, no way)
There is a patent on this in the US btw."
