Thanks to ALL for your help!!
Tao's TPU End Game - Thank You Thread
Started by chrisC, July 11, 2007, 11:44:52 AM
hartiberlin
Nice drawing and explanations EMdevices,
also many thanks to Tao for these great pics !
Maybe Tao can put also EMdevices?s pics also into his thread, then it would
very complete and also more understandable.
So it seems to have a good effect we need to wind the control coils with very
thin isolation distance directly onto the output collector coil, right ?
Also it then makes sense to have a fine stranded very big diameter output coil
for the lowest possible resistance and with many fine wires which don?t  have much skin effect.
Regards, Stefan.
hartiberlin
I have been beginning to study a bit more the audio patent from Steven Mark
and as he is using white noise for his audio process.
Maybe we should also generate these massive kicks inside the control coils
via a noise generator ?
As the TPU coils are indeed LC circuits with their L and stray capacitance C,
they will just amplifiy the right frequencies from the noise generator.
bob.rennips
Hi Tao,
Thankyou for putting all this information together. It explains the principles beautifully.
I agree that this should work and I also believe it will work but...
I've been trying to do things with electric fields for a little while:
http://www.overunity.com/index.php/topic,2607.msg37572.html#msg37572
In practice it's a lot harder to do than it appears. Differences in my approach were:
1. I've always used didoes to hold the electric field - so that could be wrong.
2. I've only ever had 3 coils in any one circle, that in total took up about 25% of the circumference of the coil. That is clearly different from having control coils touching or overlapping. I think this is very important as you highlight.
3. I was measuring the electric field as a function on how high a voltage I could hold with the diodes. The highest hold level from the BEMF I could achieve was about 600V. ( I realise holding the electric field is not what you are proposing). So using BEMF, although high voltage, is for too short a time compared with the charging time of the magnetic field.
4. I was also using speaker wire as the collector, which I think would shield the electric field ,now i think about it. duhhh!
I was concentrating more on building up the electric field in a coil and trying to transfer it to the next coil, so that the electric field voltage would get higher and higher from one coil to the next so that the voltage would be high enough for effects to happen. (Transferring didn't work).
I really think your proposal is the way forward but I think people need to be thinking in terms of very high voltage as in a few thousand volts, and not to get discouraged with this idea if there are no real results when using less that a 1000v.
I'm away on a contract for a while so won't be able to reply to any comments for a few days.
Cheers, Bob.
eldarion
OK, here is Tao's finished document in PDF form, for easy printing, etc.
Once again, thanks Tao!  Excellent work in there.
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
tao
Quote from: eldarion on July 13, 2007, 01:45:55 PM
Thanks...
Appreciate the comments, truly...
Oh, and that PDF of yours, I noticed that on page 2 the images are all shrunk...
So, below I have attached a formated PDF I made of the entire TPU: End Game document...
