EMdevices' TPU with batteries in it
Started by EMdevices, July 15, 2007, 10:33:13 AM
turbo
hi Kames  :)
did you also noticed Steven energizes these little center torroids by first placing a speaker magnet north on the right coil and then placing the south of the magnet on the left little center control torroid?
i think it is used to speed the thing up untill a moment the coil takes over and runs on it's own (catalyst).
so these can be the equivilant of what he calls the "receptors" in the open TPU where he places the magnets.
Marco.
kames
Quote from: -[marco]- on July 15, 2007, 05:05:35 PM
hi Kames  :)
Marco.
Hi Marco,
Yes, I did notice that. I don?t know how you know it was a south or north pole of the magnet. In one of the video I did notice SM was switching the poles of the magnet, for whatever reason. I did notice (especially the very first video) SM was placing a magnet on that little toroid covering a small coil and a big one, the one that was closer to the small coil.
Kames.
eldarion
I'm pretty convinced the circuit in the middle (that contains the tiny toroid and long skinny resistor or capacitor in it) is an oscillator, possibly a blocking oscillator, to generate HV spikes.
Attached is an enhanced frame grab from EMDevices' video.
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
Bruce_TPU
Hello EM,
I just wanted to give you a big public Congratulations!
Well done, my friend.  We will patiently await further details.
Highest regards,
Bruce   ;D
weri812
hellooooo  em
great!!!!! work
and thank you for sharing this video
wer
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
