EMdevices' TPU with batteries in it
Started by EMdevices, July 15, 2007, 10:33:13 AM
BEP
@Mannix
SEE!
I told you it was the Vortex forming! Better check your watch. I'll bet it is slow now too!
MACEDONIA CD
HI TO ALL
everibody like to make  tpu  in this forum  , but  i dont see reason to fake this video ok
and  to provet  that can be  a fake   ok  ,,,  is posible to make  fake whit batery ok but  way  this  gay  E.M  SO HARD  work to make  a TPU   ho can be  a fake    ,
. i thing  e.m.  is good man   but  his life  is  important   then  he  make picture  to provet  that is posible  and  that thing  can be fake  beakose  <<<<  everybody  ho  make  original  tpu  he  now  that  the his life is  in danger >>>>   that  is all  for
  make a posible  a fake  ..
                              AND NOW  EXEPLANE  AND  PROVE  THAT  CAN BE  REAL THING
  IF YOU SEE THE VIDEO  1----  you can see  in the center  in his tpu  is  a litle  neon starter   ho is  litel  of light can see
  2----  in this tpu  in the center  you can se  a  feryte  colis  ho is  separated
3-----  when a remeber  last year  i have found  a PDF circuits  in this  forum   ho  is like this      <<<  you have 3 volt batery ,, then 2 separated  neon coils  ho is is cut in  like  X  THEN   +  voltage  from batery going  in wrst in the coil   then -  going  in the anther coil    ,, then in serial is put  a litle  neon starter  then  hi going  to a amplifaer  of voltage ho increase  to H.V << HIGH VOLTAGE   I MEAN INGNITION  COIL  FOR CAR>> THEN WHAT A SAY  WHAT  SO HIGH  VOLTAGE  i say is importan  to have  a big voltage  ,,  in this out of ignation coil  you put  the  primari  coil  of tpu  then you get a moving  elektron  in the  colectors coil   ..
YOU  ask about a litle neon starter  what is a mean of that
i say this  in this starter of neon is putin back  emf force  ho is presali cut and the frekfenci  << i mean only  1 frekfenci  no harmonics frekfences   this thing <<starter >> is  perfect  transistor  ho cut the sorce   <<< YOU WHIL SEE  IN HIS VIDEO IN THIS CENTAR  OF HIS TPU  ITS  SEE LITLE SMALL LIGHT  HO ONLY  IS MAKENG  A STARTER   see the video in periode i s makeing  a litle lighh of  neon starter ...
anther  in the center is a toroid  ferite core  ho is  2 separated coils
when you  come  1 and 1  you have   oscilation ho is a
<< 1 starter  2 neon coil  and you have oscilation whiout  tranzistor  ,then only you need to increase  the pulse perfekt  frekfency << frek. whitout harmonics  >>
way whitout harmonics  ____ is importent to created real  moving of elektrones in the wire  .. if you had  a harmoniks  you get a 1000  of stepening moving elektrones  ho get a nothing ,, wrong is harmoniks  like this
YOU IN THE  second   created  1 frek.  then 2 frek. and  anther ...
and  you get nothin of moving  the  elektrones in wires  then whil hapend haotics movment of elekttrones  ho  1 elek. goin g  in 1 direction  then another ele. going in the roung direction
i say you get perfect frek. i mean only 1 frek  whil bi able  to move  elektrones  in the  same directions   you can thing about this
a say is  not  a fake  this  of E.M   a fake  whil be to security of his lfe
the E.M  most say and  prove  to all is fake  to securety his life  i now is  not a fake  but  for  apoblic  most be prove is fake
THIS  E.M  I whil congratuation  for him  this  is the best  tpu  ho even see  in this forum i mean is 90%  is real   BY
Super God
A neon starter to generate high voltage to the primary or 'control' coils...hmmm.  Sounds like a plan to me.
>9000
MACEDONIA CD
 AND  ANTHER  IF  A REAL FAKE IS  AND  IS  DC OUT  OF  90 VOLTC  WAY  IS THE CAPACITATOR  IN THE OUT   FOR WHAT  IF ARE IS FAKE what   IS PORPSE  OF PUTIN A  CAP  . IN THE OUT  IF  ARE  IS A  HAVE  10 BATERY OF 9 VOLTS    ::)
THING  THAT WAY  WHAT  WHIL YOU  NEED A CAP OF 4,7nf  and is paralel whit  resistor    ha   ha  ha
MACEDONIA CD
see  this  if you put control coil
