Tubes?
Started by Super God, July 18, 2007, 06:46:18 PM
Motorcoach1
mmmm BEP super hetrodine or that other thing Grundidg mmmm Wier ? low vaues of the tuber ELL ---- punatgmmm gezz
pese
@marco ,
same  what you like ti do with tubes
you can dio also with high voltages J-Fets !!!
Exacly same  in Input and Output - Signal an Currents..
But MOS-Fet have more the Characteristics
same as Transistors ..
If you have some Ask for that.
I have done more than 50 Years professionally worked
and experience with specially all this devices.
Find my Email in Overunity "Profil".
Pese
turbo
NO! , they can act much in the same way but they are two completly diffrent things...
that would like to say a duck is a chicken just because they are both birds and look the same but it is not right.
M.
pese
right.
SS habe not heater , not barium in the devive.
also hv rect. tube (25kv)  damper or booster dides lik GY500
make BETA radiation , and possibel that will produce also
"starnger" energies in the cathode ore anode line.
that FE that was "deiscovered in rectivier circuit from (SM?`)
was make wis rect. tubes frum 5xx# Serie.
So like 5U4  enc. You will see my tube list. all 5XX# tubes
are usefull for this.
But you will not find any energy , more than the nois taht will produced from
the boiled barium.
Pese
turbo
Hi Pese,
Steven said he origionally got the idea of electron circuits which used the rectifier tubes, not that they produce FE....
to go further you need Triodes.
The tubes first made by Lee De Forrest when he placed a spiral shaped grid between the cathode and the anode so he could influence the electron beam flowing in between.
It's intresting you mention the Gamma emission,it involves the compton scattering and all is intresting related to electron emission.
Specially because we know the voltage has to be high enough to "make the violing work" so to say.
But if that is the true behind the TPU?
i do not know, could be i hope we will find out.
Marco.
