ltseung888
My layman/scientist translation of China Patent 99126283.2 is as follows:
Title: Electricity Generator using Permanent Magnets
Inventor: Sung Tim Fat
Abstract:
This invention uses permanent magnets as source of energy to power electricity generators.  The invention includes axle, direction changer or governor, shell, stator and rotor.  The direction changer or governor is on one side of the axle.  The other components are on the other side of the axle.  Inside the shell are at least two groups of rotors and stators.  Each group contains a shell layer, a magnetic shielding layer, stator, rotator, rotating magnets and axle holder.  Stator has coils with different functions.  The rotors are attached to the axle.  The rotors have many small permanent magnets. If an extraction mechanism were added on the axle, the apparatus can be turned into an electricity generator.
*** Note that this description is very general.  The same description can be applied to the Joseph Newman, the Bedini Motor, the 225 HP Pulse Generator etc.  My major objection (also that of the Chinese Patent Office) is the first sentence ?uses permanent magnets as source of energy?.  Sung could not answer the following question from the Chinese Patent Office:
If it takes x units of energy to create or replenish the permanent magnets, how can you produce more than x units of energy in your invention?
He was granted the patent because his device rotated in front of the Patent Examiners.  We have the Video.  We later used the Lee-Tseung theory to explain the working of his invention.
Lawrence Tseung
Sung Tim Fat patent Leads Out the first and generation Cosmic Energy machines.
ltseung888
Quote from: Paul-R on August 12, 2007, 10:10:48 AM
I would urge you to file with the EPO as well if you want to
make the most of the system.
Paul.
Lee Cheung Kin and I have given our patent rights to the Chinese Government and People.  We intent to benefit the World.
It is up to the New Owner to decide the best course of action.
Sung can make his own decision on his patent.
Lawrence Tseung
Giving Patent Ownership to the Chinese Government Leads Out Peace of Mind.
brnbrade
Hi ITseung888
It can you to post a diagram of this such one cosmic device really working ?
regards
ltseung888
Quote from: brnbrade on August 12, 2007, 06:50:25 PM
Hi ITseung888
regards
The scene is Richard and Nancy at the home of Tseung.
Richard: "Looks like some members of the overunity.com forum are interested in the Sung device.  I saw that 40 minute video and was convinced that the device worked.  You can use rapidshare as the attach file limit here is only 12MB."
Tseung: "That is not a problem.  I shall zip the 96 MB file.  It should be read with Windows Media Player.   Before I do that, I shall quote the warning from the Inventor and the Chinese Police.  That video was used by some unauthorized persons to solicit funds.  It MUST NOT be used for that purpose again.  It may be used for scientific discussions only."
Nancy: "Can you repeat the story of why Sung gave up the development of his inventions?  The video seemed to indicate excellent working prototypes?"
Tseung smiled: "I shall repeat the story one more time.  Note that I use the term story because I was not personally involved.  The story was that Dr. Liang Sing Yan heard about the Sung Invention and wanted to use that invention to recharge his battery car.  They worked together for a few months.
Dr. Liang then got the brilliant idea that he could rotate the inner cylinder with ICs.  He did not need to use the permanent magnets and the complex setup of the Sung invention.  He succeeded.  All the potential investors for Sung changed ship.  Sung was obviously unhappy.  However, as a scientist, he accepted the fact that his invention was not as good.  He abandoned further development on his devices.
We also have the video on the Dr. Liang Car.  That video was definitely used by criminals to solicit funds.  Some of these criminals are in jail now.
Mr. Chao did a big improvement to overcome the hill-climbing drawback of the Liang car using banks of batteries.  That improved car traveled 1,500 kilometers to Beijing with 8 newspapers and televisions following the journey in 2006.  We have two videos.  One of them was done by the Chinese Official Television Station CCTV.
I shall post these videos when appropriate.  Here is the first one.  It will be available for 90 days.  The download time is approximately 1 hour.  The link is:
http://rapidshare.com/files/48650021/Sung.ZIP.html
Lawrence Tseung
The third generation Cosmic Energy Machines Lead Out abandonment of the first and second generation.
ltseung888
Some previous comments on the Sung Video:
(1)   It is in Chinese.  Can you translate it for us?
Try to get a friend who can speak Chinese.  If a beer cannot do it, try wine and dine.
(2)   It is too long.  Can you edit it to about 2 minutes?
I do not have the video editing tools and I do not know how to edit video.  Some also demanded an unedited video to reduce possibility of fake.
(3)   Can you summarize the video in a couple of sentences?
The first generation used a 3-cylinder setup with axle vertical.  It generated 400 watts ? enough to light a bulb, power a fan and an electric drill.  The machine needed initial power to start but the power can be unplugged after starting.  The second generation with more electronics has the axle horizontal.  It generated 20,000 watts (but very unstable with burning of electronics and coils frequently.)
(4)   Can I believe all the comments in the video?
Ignore all theoretical comments on the source of energy.  Sung was wrong in saying that the energy came from the permanent magnets.  He now believes in the Lee-Tseung theory.  Sung-Lee-Tseung are co-inventors of another flux only invention.
(5)   Should I invest in the Sung devices?
Wait until you have seen the Dr. Liang and Chao videos.  The best way is to visit Tsing Hua University or General Magnetic 磁æâ,,¢Â®and see the many working prototypes first.  The Chinese Cosmic Energy Developers with working prototypes are now highly valued in China.  The well-known ones have much funding support.
Lawrence Tseung
Working Prototypes Lead Out Funding
