ltseung888
Quote from:
http://forum.go-here.nl/viewtopic.php?p=143#143
Part 13 - Further comments on the Sung Video
Professor A: "Let me try to get the best scientific picture. The video started with pictures of the First Generation that had three cylinders mounted with the axle vertical. The first cylinder generated enough energy to feed the second cylinder. The second cylinder generated enough energy to feed the third cylinder. The third cylinder generated 400 watts."
Professor B: "It means China dropped two generations of working Cosmic Energy Prototypes. This is similar to Microsoft not selling Windows Versions 1 and 2 to the World. Is that a good strategy?"
Please put your comments in the forum.go-here.nl.
Thank you.
gyulasun
Quote from: ltseung888 on August 12, 2007, 10:48:04 PM
I shall post these videos when appropriate.  Here is the first one.  It will be available for 90 days.  The download time is approximately 1 hour.  The link is:
http://rapidshare.com/files/48650021/Sung.ZIP.html
Lawrence,
Please tell me which software do you use for watching the above video???
I downloaded and unzipped your file. I found the SungAVSEQ02.DAT file (99MB) when unzipped.  Windows Media Player cannot handle it.  In fact files with .dat extension are not known as video files but data files if I know correctly.  I may be wrong.
Thanks
Gyula
Iosh
Those kind of DAT files come from either VideoCDs or SuperVideoCDs.
That media is encoded in MPEG, so you might do well by renaming the file extension to .mpeg or .mpg and opening it with your favourite video player. In fact, that's what I did an am watching it right now.
Cheers.
gyulasun
Quote from: Iosh on August 13, 2007, 10:30:17 AM
Cheers.
Hi Iosh,
Many thanks, will do it.
Gyula
Paul-R
Quote from: ltseung888 on August 12, 2007, 05:44:50 PM
My layman/scientist translation of China Patent 99126283.2 is as follows:
Title: Electricity Generator using Permanent Magnets
Inventor: Sung Tim Fat
Abstract:
This invention uses permanent magnets as source of energy to power electricity generators.  The invention includes axle, direction changer or governor, shell, stator and rotor.  The direction changer or governor is on one side of the axle.  The other components are on the other side of the axle.  Inside the shell are at least two groups of rotors and stators.  Each group contains a shell layer, a magnetic shielding layer, stator, rotator, rotating magnets and axle holder.  Stator has coils with different functions.  The rotors are attached to the axle.  The rotors have many small permanent magnets. If an extraction mechanism were added on the axle, the apparatus can be turned into an electricity generator.
*** Note that this description is very general......
Yes, it is. It says nothing.
To be of value to the patentee, a patent must reveal the technology to be patented. That is the deal. Disclose to the world in return for a 20 year period of protection.
Unless the patent discloses, it will be of no value to the patentee. It will not hold up in court.
