0 Members and 51 Guests are viewing this topic.
ltseung888
More information on the use of ICs to pulse rotate the Cylinder.
(1) The Intelligent Chips (ICs) can be programmed to exhibit property of magnetic North Pole, South Pole or No Poles.
(2) One set of ICs is on the rotating cylinder.  Another set is on the non-rotating cylinder. Their interaction pulse rotates the cylinder.
(3) The Rotating Cylinder will be driven to a certain designed speed by a separate starter motor.
(4) We are absolutely certain that gravitational energy is Lead Out because the engine works best on level road or surface.
(5) Tilling the axle from the horizontal to the vertical will reduce the power output.  When the axle is at the vertical position, the output power is close to zero.
(6) The amount of power generated depends on the following factors:
      - speed of rotation
      - the pulse rate (programable)
      - the number of ICs (several hundred used)
      - Diameter and weight of the Cylinder
(7) There is a sensor to detect the external load and adjust the program accordingly. (Some ICs can be programmed to No Pole)
(8) The Published Data from Liang is that a 28Kg engine could generate 188 Horse Power.  (See picture in section 4.3 of the previous mentioned TPU theory1-8.doc)
(9) In the Liang demonstration, once the engine started, the battery was disconnected.  The engine kept on running.
(10) Lee Cheung Kin, who spent a week working with Chao, was convinced that the Chao engine is similar to the Liang engine in principle.  The Chao factory and the Liang laboratory are in the same small town.
Are these IC in reality MIC, magnetic -integrated- transistors,
with Bloch/Weiss  domain/wall controle ?
S
  dL
brnbrade
hmmmm!!!
brushless motor ? Ics Controller...
sounds nice
Humbugger
Quote from: ltseung888 on August 15, 2007, 07:56:55 PM
Quote from: Iosh on August 15, 2007, 07:44:12 PM
I think that by ICs he means Intelligent Chips, according to the .doc file he posted earlier.
I don't know what kind of devices are those though. Help, someone? ???
These Intelligent Chips can be programmed to show the effect of North Pole, South Pole or No Pole.  They are usually grouped together with the Hall Effect ICs.
In the Liang China Patent, he quoted China IC 3001 and IC 3008 as examples.  He used seven hundred of each of these if I remember the numbers correctly from his meeting.
I do not know whether there is an equivalent outside China.
Lawrence Tseung
Studying the details of the Published Patents Lead Out confidence in the invention.  Meeting the inventor in person is even better.  Driving the actual car is best.
Please post a link to a data sheet or tell us the manufacturer of these Chinese ICs.  I don't believe they exist.
Also, am I understanding that 700 of these ICs were sufficient to power an automobile?
Without using any electromagnets or other motors whatsoever...just these ICs?
Thank you
Humbugger
Quote from: brnbrade on August 15, 2007, 09:37:26 PM
hmmmm!!!
sounds nice
Do you just automatically believe in everything, Brnbrade?
