0 Members and 28 Guests are viewing this topic.
Top Gun
Dear Mr. Tseung,
Thank you for answering my previous four questions.
My fifth question is:
(5) Can you compare the Bedini/Adams motor with your Flying Saucer Rotation Mechanism in 1165?
Koen1
@Top Gun: If you're not one of Tseungs many alter egos, I'd have you know that Tseung clearly doesn't know anything about Beardens theoretical work.
Do not expect him to give any proper explanations that tie into Bedinis work or theories.
In fact, do not believe a word he says. He talks nonesense all the time. He's probably not even educated in physics. And possibly not even Chinese.
hansvonlieven
Quote from: Top Gun on February 02, 2008, 07:18:09 PM
Dear Mr. Tseung,
If you add coconuts to Bedini's system it will fly! But only if you have proper Lee-Tseung Pulls instead of these silly pulses Bedini uses.
He should study the Lee-Tseung Lead Out Theory, then he too could have a flying saucer.
Hans von Lieven
ltseung888
Dear Mr. Tseung,
I shall divide the answer into many parts.  This is the first part to Question (5).
The Lee-Tseung Patent information (PCT/IB2005/000138) was formally revealed to the World in July 2006 via the International Patent System.  The Patent Information revealed that electron motion (magnetic) energy could be Lead Out via pulsed rotation of magnets in magnetic fields.  This is the theoretical basis for almost all of the known rotational systems including Newman, Bedini, Adams, 225 HP pulse motor, Wang, Liang Motors.
All these so called over unity inventions existed before July 2006.  These inventors did not have knowledge of the Patent Information and hence the theory before that time.
In USA, the most well known over unity inventor was probably Joseph Newman who had an over 40-year struggle with the US Patent Office.  Information on his invention is available in http://www.josephnewman.com/.  A brief description of his machine and story is also available in http://en.wikipedia.org/wiki/Joseph_Newman_%28inventor%29
Figure 1  below and brief description is from wikipedia:The Energy Machine of Joseph Newman is a singly-fed electric motor consisting of a permanent magnet field rotor that spins end-over-end inside an electromagnet that is both an stator and an armature.
Mr. Newman, the inventor, says all magnetic fields consist of particles with a gyroscopic spin. The inventor says he cannot get more mechanical energy out of the machine than the mass-energy it inherited.  He claims this inheritance allows the machine's mechanical rotor output to be greater the electrical power it receives.
In the Lee-Tseung theory, the Newman Machine is just a rotating magnet in a magnetic field with a DC Pulse.  The Driving Coil happens to be the Pickup Coil also.  The rotating magnet Leads Out Electron Motion Energy that is available in all objects.  When the axle of rotation is horizontal, it will lead out gravitational energy at the same time.
Mr. Newman successfully demonstrated that the batteries could be recharged with back EMF while the machine was used to do work such as driving a car.  He realized the more massive the machine and higher the rotational speed, more work could be done.
(to be continued)
gaby de wilde
Quote from: ltseung888 on February 03, 2008, 06:12:59 PMWhen the axle of rotation is horizontal, it will lead out gravitational energy at the same time.
hi,
Yes, interesting gravity effects with the Newman machine.
I had created this topic.
http://www.overunity.com/index.php/topic,4039.msg74842.html#msg74842
Here are 2 images from it illustrating my main invention there disclosed. :)
Can save a coil you see?
And....
This is like having 2 Newman machines in one and the same location.
The rest of the topic is about creating a grid for further magnetic-entrainment.
Here is an illustration of a block of 3X3X3
I assume the Newman machine to be far overunity like this. The 27 fields are not lost but they all overlap, that seems like more then enough free energy to me. :)
Have fun with it.
blog  | papers | tech | inventors  | video
