0 Members and 112 Guests are viewing this topic.
Top Gun
Welcome back, Mr. Tseung.  I like your description to Slide 13.
I would like to make it more general.  I replaced the 2 units with X and the 1 unit with Y.  Over Unity Device replaces the pendulum system.
The modified Slide can be applied to many different known, documented Over Unity Inventions.  The Inventors will be much clearer on where the energy comes from.  Note that I used Lead Out Energy.  That includes gravity, electron motion or any other source that might come out later.
The heart and soul of this Slide is the Lead Out Energy.  We spent many posts and much vigorous physics and mathematics to bring out the concept.  Now we can enjoy the fruit.
ltseung888
I would like to discuss Slide 14 now.
In this slide, we extend the extraction or lead out of energy to magnetic energy.
The bob of the simple pendulum is replaced by a magnet.  Optionally, magnetic shielding material can be added to improve the effect.  In the figure, the South pole of the magnetic pendulum is attracted by the North pole of a permanent magnet at the bottom and repelled by the South pole of a permanent magnet at the top.
This effectively increased the gravitational constant(G).  The value can be much more than 9.8 meters per second per second.
If we can extract or lead out gravitational energy, we can indeed extract or lead out magnetic energy in a similar fashion.
Magnetism is a result of circular electron motion.  Thus ?Leading out? magnetic energy can be equated to ?leading out? electron motion energy.  We shall discuss this concept more in a following slide.
Top Gun
Mr. Tseung,
I would have used the much simpler slide as shown.
There is no need to introduce additional complexity.
ltseung888
Quote from: Top Gun on April 04, 2008, 10:21:31 PM
Mr. Tseung,
Dear Top Gun,
You are right as always.
When I drew that Slide, I was thinking  of the Wang Shum Ho device.  That particular device uses magnetic shielding material.
The Forever Yuen experiment uses your particular diagram.  She flipped the large permanent magnet to have S pole on top to produce repulsion.
I think it is clear to the average person that if the simple pendulum can lead out gravitational energy, the magnetic pendulum will be able to lead out additional magnetic energy.
ltseung888
Dear Top Gun,
I just finished a long session using your slides with an engineer.  Here is his feedback:
(1)   The slides are too detailed.  He got bored.
(2)   He said that we should just say:
(3)   Horizontal Force cannot do vertical work.
(4)   The applied force F is horizontal and that there is displacement horizontally.  Work is done by F in the horizontal direction.
(5)   However, there is an increase in height.  Work must have been done in the vertical direction.
(6) Which force is responsible?  Out of the three forces involved, it cannot be F.  It cannot be the weight.  The only choice is the tension of the string.
He was quite happy to accept that the tension of the string did the vertical work and thus lead out gravitational energy.
(to be continued)
