0 Members and 135 Guests are viewing this topic.
ltseung888
The Engineer also asked the same question as one of the Forum Members.
If the string is not shortened, can it do work?
He satisfied himself with the following diagram.  The string does not shorten in the pulling of the weight at an angle.  Work is done by the horizontal component of the string.
The string does not get shorter in this case.
ltseung888
Dear Top Gun,
My new slides for the old slide 12 are slide 12m and slide 12n.
The description for slide 12m is:
In physics, work is equal to force times displacement using vector arithmetic. By vector arithmetic, we mean the direction needs to taken into account.
One common way is (1) to resolve the force into a vertical and a horizontal component
(2) to resolve the displacement into a vertical and a horizontal component
(3) the horizontal work is equal to the horizontal component of the force times the horizontal component of the displacement. In this case, horizontal work is equal to F times L times sin(a)
(4) The vertical work is equal to the vertical component of the force times the vertical component of the displacement. In this case, vertical work is equal Mg times L times [1 minus cos(a)]
It is important to realize that horizontal force cannot do vertical work because the direction of the force and the direction of displacement are at right angles to each other.  Thus the vertical work is not done by the supplied horizontal force (or energy).
One common mistake is to assume that all energy supplied is from the horizontal pull without doing the detailed force, work and energy analysis.
ltseung888
The description for slide 12n is:
After we substituted the actual values, the horizontal work performed by F has a value of 16.10728 joules.
The vertical work performed by the string has a value of 7.0069 joules.
The ratio of horizontal energy over vertical energy is thus 16.10728 over 7.0069 and equal to 2.014.
Therefore, approximately 2 parts of horizontal energy leads out one part of vertical energy. This is the essence of  the Lee-Tseung Theory.
Top Gun
Quote from: ltseung888 on April 05, 2008, 05:14:02 AM
Dear Mr. Tseung,
I like your aggressive style.  You pointed out the common mistake right away.  It will force the other side to defend that they have not made a mistake.
This strategy saves much explaining.  If they are good like the professors and research students at TsingHua or Shenzhen University, they would find the mistake.  Many do not care.  There is no need to explain to them.
A few may ask questions.  But this forces them to think first.
ltseung888
Here is the description for Slide 15.
In this slide, we extend the concept to rotational systems.
On the left hand side, the unbalanced wheel has a small weight attached to the rim.  When we give a small clockwise rotation to the wheel and let go, the wheel will rotate back in an anti-clockwise direction.  If we focus on the small weight, the action is the same as the simple pendulum bob.
If we consider one complete revolution of  the unbalanced wheel, we would find that on the upward rotation, the unbalanced wheel will slow down due to the small weight.  On the downward rotation, the unbalanced wheel will speed up.  This speeding down and speeding up produces a pulse that can lead out gravitational energy.  In the 17th century, a watch maker in Germany produced a Bessler wheel.  That 16 feet wheel claimed to be able to lift small weights and kept rotating for 90 days.  Theoretically, it is possible because the Bessler wheel might just be an unbalanced wheel.
On the right hand side, we have a balanced wheel.  We can have multiple pulse points on this balanced wheel.  The balanced wheel can rotate at high speed.  Thus we can lead out much more energy.  If we have magnets on the wheel pulsed by electromagnets and surround the device with suitable magnetic fields, we can draw out both gravitational and magnetic energy.
Many documented and demonstrated Over Unity devices use these rotating magnets in pulsing magnetic fields.  Some of these working prototypes will be discussed in the following slides.
