0 Members and 117 Guests are viewing this topic.
ltseung888
Quote from: ltseung888 on April 05, 2008, 08:15:37 AM
Here is the description for Slide 15.
In this slide, we extend the concept to rotational systems.
It is almost impossible to discover the Lead Out Energy mechanism from rotations.  Lee and I were lucky to have started with the pulsed pendulum.
However, almost all practival OU invention prototypes use rotation.
Please try to understand slide 15.  Once you mastered it, you would have mastered over 200 OU inventions worldwide.
ltseung888
This is the description for slide 16.
In this slide, we shall emphasize the Electron Motion Energy again as promised.
(1) When an electron moves in a circular orbit, it creates magnetism.  Magnetism is related to electron motion.
(2) When electrons jump from one orbit to another, they can emit light or electromagnetic waves.  The Laser is a well known example.
(3) Electrons can be detached from the atoms of some elements and cluster together.  This clustering produces electrostatics.
(4) Electron flow creates the AC or DC current that we use daily.
(5) Electrons exist in all atoms.  They are moving around the nuclei all the time.  If they stop moving, they might be attracted and fall into the nucleus.  We are using the existing energy of moving electrons.
(6) The electrons keep exchanging energy with their surroundings.  An example is the black body radiation.  All material emit or absorb light or electromagnetic waves all the time.
(7) Chemical Energy is due to different configuration of electron clouds of different compounds.
If we can lead out energy from a magnetic pendulum, we should be able to lead out energy from an electrostatic pendulum.  Thus, we use the term ? leading out energy from electron motion.
ltseung888
ltseung888
Slide 16 answers the question - do we draw energy from the magnetism of the permanent magnets?
The answer is NO.  We Lead Out energy from Electron Motion.
This new concept will need time to digest.
ltseung888
This is the last theoretical slide.
In this slide, we essentially summarize the steps discussed previously and project some more.
(1) We are in Gravitational and Electron Motion Fields.
(2) Pulsing Pendulum Leads Out Gravitational Energy
(3) Pulsing the Magnet Pendulum can Lead Out Electron Motion (magnetic) energy
(4) An unbalanced rotating wheel is equivalent to a pulsed pendulum
(5) A pulsing balanced rotating wheel will Lead Out Gravitational or Electron Motion Energy efficiently.
(6) Inventions from Newman, Bedini etc. use 4 or 5
(7) Flying Saucer does not need to eject gases (use inertia propulsion)
(8 ) Flying Saucer uses new energy (no fossil fuel)
We shall discuss Flying Saucers in a separate seminar.
