Devil
Tseung, you can use your above article on almost all the 300 known lead-out-energy inventions.
Do not worry about the insults and jeers.  Let them recite the following 666 times.
(1) The Lead-out-energy from a horizontally pulled pendulum is equal to the vertical component of the tension times the vertical displacement.
(2) An unbalanced force can be generated from a closed system.  Secondary events using unequal exchanges of energy and momentum are used.
(3) The electromagnetic Coil can be a magnet, a collision mechanism and an electricity exchange mechanism.
Devil
Tseung, I modified your general article to other lead-out-energy inventions.
Theory behind the lead-out-energy inventions (e.g. Bedini)
We can classify machines into three types.
(1)   Output energy plus loss is equal to input energy.  This is the traditional form of machines.  There must be continuous supply of input energy for these machines to function.
(2)   Output energy is larger then input energy.  These are known as over unity machines.  They violate the Law of Conservation of Energy.  Energy is created from nothing.  Such machines are regarded as impossible perpetual motion machines.
(3)   Input energy will lead out other forms of energy such as gravitational or electron motion energy.  The concept was publicly described in the PCT patent titled ?Extracting Energy from Gravity? by LEE Cheung Kin and TSEUNG Lawrence Chun Ning.  The number is PCT/IB/2005/000138 and published on July 27, 2006.  (http://www/wipo.int/petdb).  Our invention (Bedini) belongs to this class of machines.  Thus our invention does not violate the Law of Conservation of Energy.
In this type of lead-out-energy machines, the input energy can lead out existing energy.  For example, in the case of a pulled pendulum under a horizontal input force, approximately 2 parts of horizontal input energy can lead out 1 part of vertical gravitational energy.  3 parts of energy appear on the output.  1 part can be used to do work or generate electricity.   2 parts of the output energy can be fed back to the input to lead out another 1 part of gravitational energy.  Thus the lead-out-energy machines require only 2 parts of starting energy and they can continuously lead out gravitational energy to do work.  They do not violate the Law of Conservation of Energy.  They do not create energy from nothing.  They use existing gravitational energy.
In the Lee-Tseung PCT patent, they extended the above concept to pulsed rotational systems in magnetic fields.  Magnetic or electron motion energy can be led out in a pulsed rotational system.  More information on the Lee-Tseung theory is available on the Internet (http://www.energyfromair.com/IOE_talk) or via the Book by Lawrence Tseung titled ?Innovation ? the story of Lawrence Tseung?.
The Bedini invention is a pulsed rotational system in magnetic fields.  The system is pulsed by DC current through an electromagnetic coil.  The end of the electromagnetic coil essentially shows properties of North Pole, No Pole, North Pole, No Pole, etc.  This electromagnetic coil repels the permanent magnets with North Pole facing outwards on a rotating wheel.  The arrangement will lead out magnetic energy.  The wheel will rotate faster and faster.
In order to extract the lead-out-energy, a collector coil can be used.  In the case of the Bedini invention, the same electromagnetic coil is used as collector coil.  The collected electricity is used to recharge batteries.  This Bedini system works but can be improved with multiple pulse coils, multiple collector coils and a program control to adjust the pulsing current according to external load.  (The improved system is effectively the 225 HP Pulse Motor.)
*** The above short theoretical description is likely to appear on all lead-out-energy invention announcements.
***** There is no need to introduce stupid concepts such back EMF and Zero Point Energy.  Humans are stupid - that is a fact of creation.  They are of an inferior design than us immortals.
Pirate88179
You forgot to mention the Bedini motor makes good use of the bifilar and/or trifilar coils. Leaving out a basic,
fundamental part of the system like this shows how little you understand this device.
It would be like trying to describe how an airplane works but then leaving out the part about the wings.
The comedy here continues.
Devil
Quote from: Pirate88179 on September 02, 2008, 01:29:41 AM
Stupid humans.  The bifilar and/or trifilar coils are stupid designs when Bedini uses the same coil as pulse and collector coils.  When you use the Adams or the 225 HP Pulse Motor design, such coils are not necessary.
When you do not understand the stupid theory, you treat every component as sacred and thought that they were necessary.
That is why many stupid followers of Bedini could not get their prototypes to work.  They did not see the link to the much more efficient 225 HP Pulse Motor.
*** On another note, the airplane is stupid.  Using aerodynamic surfaces is like opening the door of your car, hoping the force of the wind will slow it down.  Wings are not necessary in the flying saucer.  Stupid.
chrisC
What did you expect from a wannabe 'scientist' that gets no respect? Maybe Lawrence should change his name to Roger?
Just a though. Maybe he'll get to star with Jackie Chan the other clown!
cheers
chrisC
