ltseung888
please see:
http://www.overunity.com/index.php/topic,3260.msg50656.html#msg50656
on the drawback of the existing Chas Campbell Flywheel device.
It looks like that the Lee-Tseung Lead Out theory can explain it and show how to improve it.
Lawrence Tseung
Pulse Rotation consideration Leads Out direction of improvement for the Chas Campbell Device.
ltseung888
Calculation based on Dr. Liang Xingren Car
Mass in Kg      28
Radius in Meters      0.4
Rate of revolution in RPM      4500
Effective rolling velocity in m/s of Cylinder v = 2*pi* r * RPM/60
188.496
Stored Energy of Cylinder = 1/2 * m * v * v in Newton-meter (joule)
497430.3882
"Assume that such energy can be drained or supplied within x sec, power  in Newton-meter/second (watt)"
165810.1294      if x =    3
Assume 745.7 watts = 1 horse power
The Dr. Liang Car in Horse Power
222
I have done the spreadsheet to estimate the horse power of a Pulse Motor based on the known or estimated values of the Dr. Liang car.
The car claimed to have a HP of 188.
The spreadsheet gave a figure of 222.  This means that the Dr. Liang Car is within the rim of possiblilty.  The spreadsheet is attached.  You are welcome to play with it and use it for other pulse motors.
ltseung888
The preliminary Chas Campbell Flywheel Generator report.
Please see:
http://www.overunity.com/index.php/topic,3260.msg50900.html#msg50900
Reply to comments from Hans:
*** Note:  The Lead-Out is best at high rotational speed.  The Lead-Out energy at low speed is very low.  Thus in the Liang motor, a separate starting motor is used to get the Cylinder to the designed speed of 4500 rpm.  (Experiments showed that without the Starting Motor, the IC pulses just could not start the rotation!)
The Equilibrium Rotational Rate can be maintained with just a small percentage of ICs taking part in the Pulse.  For example, there are 800 IC pairs.  The number of IC interactions required to maintain equilibrium rotational speed at no external load may be 50.  (Another way of maintaining the equilibrium rotational speed may be to have 100 ICs Pulsing at half the previous rate). When the external load increases, the program can pulse up to an additional 750 pairs to increase the Pulse Force.  That could keep the cylinder to rotate at approximately the same speed or even higher.
The Energy drained or supplied at such high rotational rates is very different from what is experienced in daily life.
Regards,
Lawrence Tseung
Energy Lead Out at high Pulse or Rotational Rates is very different from what we experience in our daily lives.
ltseung888
Phone Conversation with Wang Shum Ho.
Tseung: "The Mid-Autumn festival is coming in a few days.  Are you having any special celebrations??
Wang: ?Thank you for calling.  I am in Beijing working hard with others to plan for the IPO next year.  There is so much to do.  What is the progress on your side??
Tseung: ?I am working with the overunity group on the evaluation of the inventions from Chas Campbell of Australia.  It looks like that he has a very early version of an Electricity Magnifier.  He has not written the program to vary Input Power with changes in External Load yet.?
Wang: ?I do not worry about him as a potential competitor.  The EBM and the Pulse Motor are well ahead of him.  Your disclosing the possibility of building the Flying Saucer with another ring around the Pulse Motor is very stimulating.  Good luck.?
It appears to me that Newman, Bedini, Searl etc. may not realize the importance of program control to match the Input to the External Load yet.
Lawrence Tseung
Magnet rotating around the Pulsing Coils Leads Out possibility of the Flying Saucer
ltseung888
I have now edited Campbell1-5A to include the comparison with the 225 HP Pulse Motor.  Edited to add comparison with Wang Generator.
It is attached here as Campbell1-5B.doc.  It should be obvious to the scientifically minded investors on what to invest.
Have fun.  Comments are welcome. Enjoy the Mid-Autumn Festival. Chew on the Moon Cakes while you think! ;)
Lawrence Tseung
Comparison between Pulse Motor and Chas Campbell Flywheel Leads Out clear choice for investors.
