0 Members and 28 Guests are viewing this topic.
Top Gun
Mr. Tong did the improvement as shown in the figure.
He is absolutely certain that he can:
(1) Produce enough force for the cylinder to jump vertically even a couple of meters.
(2) The force produced will be sufficient to carry a small battery to jump up together.
(3) The Pulse strength and rate can be adjusted to be in many pulses per minute.
All the elements of producing a flying saucer prototype is available.
If the Lee Tseung theory that unbalanced forces can be produced from within a system, a prototype can be developed to fly, hover, move left and right, vertical take off and land.
Lee Cheung Kin and team took 6 months to get a working prototype.  Mr. Tong took less than 3 weeks to come up with a possible theme.  I am sure other possible ones will emerge shortly from China.  (The USA scientists may believe the non-physicist forum members here.) :D :D :D
What you have outlined above is not an attempt at falsification, it is an attempt at verification.
Let me tell you what I mean. I have here a foolproof black cat detector. It only responds to black cats, and nothing else. How will we test it?
Your experiment is equivalent to testing my detector by showing it a black cat. When it lights up, you would say my detector is proven.
However, the correct way to test the detector is to present it with something OTHER than a black cat, and see if it lights up. If it does, it really isn't a black cat detector, is it, even though it passed YOUR test.
Now, on to the above experiment.
When the moveable magnet strikes the top wall, of course the assembly will "jump" up--assuming the other parts are light enough and the magnet strikes with sufficient force.
When the electromagnet pulses, though, the table experiences a reaction force.
This means, if the apparatus were suspended in space, at the moment the electromagnet is triggered, the housing and electromagnet will be pushed downward at the same time, and with equal momentum, as the moveable magnet is pushed upward. Then, when the moveable magnet hits the top wall, there is another, symmetrical wrt momentum, interaction. The net motion of the center of mass is zero.
Please ask Mr. Tong to suspend the device as a pendulum and make it sustain a horizontal displacement. Or explain what happens in the vertical orientation when there isn't a table to push against.
And of course your next statement is complete garbage.
In the first place, all the motion of the device comes from reaction against a substrate. I don't care how powerful the pulses are or how light the batteries are. It won't jump unless it pushes off of something!!
WHY in the world don't you show a test of this simple proposal?
A proper frictonless surface for the horizontal version.
A pendulum or hover test of the vertical version.
Show such a demo, or please STFU about the non-existent flying saucer.
And, finally for now, does anyone notice that the horizontal version above, is IDENTICAL to one that I showed in my video, tested as a pendulum, that did NOT show motion of the center of mass?
Top Gun
Quote from: TinselKoala on December 09, 2008, 11:07:36 AM
Your set up could not even do the simple Experiment001.
Your solenoid could not even repel the magnet away.  Please do Experiment001 correctly.
How can it be identical??? :D ;) ::)
