critic
Dear Mr. Tseung,
I think that your Flying Saucer theory depends on the fact that â€" an unbalanced force can be produced for propulsion purpose from within a closed system.
The direction and the magnitude of the force are immaterial in the theoretical discussion.
In the youtube video http://hk.youtube.com/watch?v=W2qKRmhWdd8, it is clear that the unbalanced force is produced by the collision of the car with the box.  External friction does not play any role.  The surfaces between the box and the ground can be perfectly smooth, the box will still move due to the internal collision.
The Tong device placed horizontally http://hk.youtube.com/watch?v=-TfwKBdmRao, shows that unbalanced force can be produced from the interaction of magnets and electromagnets.  The pulsing rate is important.
The Tong device placed vertically http://hk.youtube.com/watch?v=W2qKRmhWdd8, shows that while the gravitation force is constant, the pulse force is not.  It is a matter of combining a number of pulsing forces so that they appear to be constant.  This requires much experimentation.  However, the theory that an unbalanced force can be generated from within a closed system is proved beyond doubt.
I believe that you can already write scientific papers with your theory and the Tong device.  The China Patent Office will accept and approve your patent application.  Hundreds of researchers can easily reproduce the Tong device â€" especially with your clear write-up and the coming workshops.
I know that you believed that the Military Research Establishments in China, USA and other Countries already developed some form of man-made flying saucers.  However, I still think that you can benefit the World with your step-by-step version.  They can remain top-secret and confidential.  You can be open.  The openness will do more good to the Human Race.  As you mentioned â€" the Earth is round no matter what the authorities (or other forum members) say.
hansvonlieven
Quote from: ltseung888 on January 16, 2009, 07:33:19 PM
The Flying Saucer Experiment Parts can be ordered in Hong Kong.
The parts include:
(1) DC power supply
(2) Timer devices
(3) Soft Iron Core
(4) Coated copper wire
(5) Switches
(6) Resistors
(7) Magnets, Tubes, Tapes and other accessories
The owners are the Chan brothers and they helped to select the testing equipment.  They have seen some of the early test results.  When the Tong Po Chi device is finalized, they will be able to sell you a DIY package.
G'day Lawrence
Dont forget the one way valves, the one way valves, the one way valves !!!!!!!
Hans von Lieven
ltseung888
Quote from: hansvonlieven on January 17, 2009, 05:24:50 AM
G'day Lawrence
Hans von Lieven
Do not confuse the Energy from Air Workshop from the Tong Po Chi device workshop.
Dr. Raymond Ting is in charge of the Energy from Air Workshop.  Attached is his presentation in Chinese and an early paper from me in English word format.
Know how to use the one-way valves properly.
ltseung888
Platform to demonstrate the Flying Saucer Proof-of-Concept prototype.
The platform is set up as in the diagram.  The important trick is to place the permanent magnet just above the electromagnet to produce the repulsion.  If the permanent magnet is placed too low (inside the coil) or too high (away from the coil), the repulsion effect cannot be demonstrated.
This trick is achieved by taping the permanent magnet on top of a short piece of plastic tube.  The electromagnetic coil can also slide up and down the clear plastic tube.  It can be fixed in position with rubber rings on top and on bottom.
The first test was done with Number 18 copper wires (20 and 120 turns) at 12 Volts and approximately 3 amps.  The initial test is for the permanent magnet and the attached plastic tube to jump up due to repulsion.  At the beginning, we did not realize the importance of the trick â€" placing the permanent magnet at the right position.  Much time was wasted.  Towards the end, we were exhausted but were able to show that
(1)   The more turn set up showed a larger repulsion
(2)   The permanent magnet and plastic tube jumped more than 10 cm inside the clear plastic tube.
We believe that the above is a good platform to get started.  We shall experiment with at least:
(1)   Different size copper wires
(2)   Different number of turns
(3)   Different Voltage and Current
(4)   Different Permanent Magnets
(5)   Different Weights of the Permanent Magnet+Plastic tube
The goal is to produce the maximum repulsion force before the next step.
Top Gun
Dear Mr. Tseung,
I like your describing even the building of the Platform.  Tinselkoala said that he could not produce an electromagnet to repel the permanent magnet.  The permanent magnet stuck to the soft iron core.
Your platform explained that very well.  Before the electromagnet is switched on, the permanent magnet will attract and induce magnetism to the iron core.  The current to the electromagnet must be strong enough to reverse the magnetism of the iron core to show the repulsion effect.  Tinselkoala did not do a thorough investigation and just claimed that the experiment could not be done.
This is the problem of letting a non-believer do the experiment.  He will just give up at the slightest difficulty and claim that the theory is false.  He will claim that the effort is a waste of time.
You now have believers in your camp, Mr. Tong Po Chi, Dr. Raymond Ting, the Chan brothers, Ms. Forever Yuen and team.  You will have more after the mini-workshops.  Your step-by-step approach can be replicated by the knowledgeable.  You do not need to produce the final product immediately.  The World benefits more when it sees innovation in action â€" not just results.  You can give the Tong Po Chi device as a present to the Chief Executive of Hong Kong, the President of China and President Obama.  They will have the top academics evaluate and improve on it.  That will inevitably lead to the full development of the man-made flying saucer.  (China and USA may already have much more advanced flying saucers as top-secret projects but your open letters and gifts will benefit the World.)
Continue your existing approach.  The Earth is round no matter what the authorities (or some forum members) say.  You are effectively sailing around it.  The journey may have many unknowns but there will be many pleasant surprises.  You are on the way in discovering new continents.  Others will join you when they see the excitement.  Bon Voyage!
