chrisC
Quote from: utilitarian on February 03, 2009, 11:25:48 AM
I think TK put it best.  You have invented jumping!  Congratulations.
Er, it's like old Tseung is becoming younger as he gets older aka Benjamin Buttons(?).
Now he thinks he's invented the solenoid and making it jump!!!
de'ja vu - It's all 'O' level Physics again!
cheers
chrisC
hansvonlieven
Well done Lawrence.
I suggest you write a book. It is sure to outsell the Bible, just as your other book did.
Here is the suggested layout.
Hans von Lieven
Quote from: ltseung888 on February 03, 2009, 11:16:06 AM
The attached picture showed the Dr. Raymond Ting improvement.  The coil attracts the magnet to move rapidly upwards,  As soon as the magnet reaches the middle of the coil, the upward momentum (force) is changed to a downward force.  The upward momentum carries the entire tube upwards.
From momentum consideration:   M1 * V1 = (M1+M2) * V2 and
From energy consideration:          (M1 * V1*V1)/2 = ((M1+M2)*V2*V2)/2
The resulting jump height is greater than 180mm.
Please put a strain gauge or pressure sensor under the device, between the table and the device. Report the results. Then you may presume to teach us some momentum conservation equations. Until then, that is until you do the PROPER CONTROL EXPERIMENTS, you are just blowing smoke. And it isn't even "sweet smoke".
Top Gun
Quote from: ltseung888 on February 03, 2009, 10:10:55 AM
Some early results of Experiments:
http://hk.youtube.com/watch?v=SrhQIxFlN-w&feature=channel_page
The following set up was used:
(1) A HK$25 Cylindrical Magnet
(2) A 12 Volt power supply
(3) 20 turns of Number 18 copper wire
(4) Transparent tube of 130 mm length
The results are:
(1) Use repulsion - jumped 120 mm approx.
(2) Use attraction - jumped 180 mm approx (the youtube video)
Dear Mr. Tseung,
You have invented jumping in three ways:
(1)   Use repulsion between solenoid and permanent magnet
(2)   Use attraction between solenoid and permanent magnet
(3)   Use both repulsion and attraction between solenoids and permanent magnet.
I am sure that you can invent additional jumping techniques such as:
1.   Use repulsion between solenoids
2.   Use attraction between solenoids
3.   Use both repulsion and attraction between solenoids.
I think you can focus on (2) using attraction between solenoid and permanent magnet.  The present jump height is already 180 mm.  Try the combined twin device M and N double jump when ready.  That is the definitive experiment.
You would then have invented jumping in mid-air.  That is another Nobel Prize achievement.  The insults and jeers will continue but the Earth is round.  Continue to triple check and publish the detailed experiments.  The World is benefiting.
chrisC
Quote from: Top Gun on February 03, 2009, 05:14:26 PM
You would indeed get a Nobel prize if you can try washing a piece of charcoal with water until it turns white!
It will never happen. Just like your childish experiments. Any 'O' level Physics student can tell you in no uncertain terms that you need to see a doctor.
Dream on Dork!
cheers
chrisC
