0 Members and 115 Guests are viewing this topic.
ltseung888
The repulsion of the permanent magnet to more than 1200mm gave Dr. Ting much confidence that the double jump was possible.
This and other experiments can be viewed at his site on youtube.com.  I shall wait to give the actual links as there seems to be problem uploading this afternoon.
Much tuning was required to achieve the highest possible jump.
I also spent many hours trying to develop a feel of the right tuning.  I cannot claim to be an expert yet.  However, I am improving.
ltseung888
This picture shows the configuration used to pass current to both coils at the same time.
We can achieve a height of over 180mm with a single tube.  We should be able to achieve approximately the same height with current to both coils.  The two coils from the two devices are effectively connected in series.
The resulting height was closer to 130mm.  One important reason may be the effective lowering of current when the two coils are connected in series.  Another reason may be the additional weight of the foam and tapes.
To allow for a smooth vertical jump, Dr. Ting made a hole in the foam and put in a vertical stick.  However, that introduced much friction.  He decided to use the simple direct jump test instead.
One difficulty with M jumping to get both tubes up is that the device tend to turn or rotate.  However, we noticed the sending of current to N will turn it back.  That helps in the theory that we can provide force and turning moment in mid-air.
ltseung888
The last picture in this series is the use of two on/off switches.
The human hand is used to start one and then the other.
The person doing the experiment gets the feel - myself included.  However,  we should have proper measurable and detectable figures.
Thus the next test will include a timer to delay the starting of the second circuit.
That will be much more convincing and much more reproducible.
Meanwhile, have fun.  Enjoy the pictures and the videos.
tagor
have you seen this video ? :
http://www.youtube.com/gilbondfac?gl=HK&hl=zh-TW
this smot accelerate so fast , can you use it ...
ltseung888
Quote from: tagor on February 04, 2009, 01:12:54 PM
Thank you.  Dr. Raymond Ting and other who are building the WBLT will love it.
Keep these constructive information coming.
