0 Members and 115 Guests are viewing this topic.
ltseung888
Use of Timers
This article describes the use of timer to control the motion of the Tong Po Chi device.
The timer we used was the DH48S-S.  It can be driven by 12V and can take a current of 5A.  The circuit is shown in the attached diagram 1.  There are two time periods â€" T1 and T2.  The time period T1 is set to 0.1 seconds.  This period is used to send the DC Pulse Current.  The time period T2 is set to 2 seconds.  This period is the idle time before the next pulse.
The external connection wires are shown in RED in diagram 2.  A variable resistance of 8 ohms is attached to limit the current to less than 5 Amps to protect the Timer.
ltseung888
If we want to use two coils with the DH48S timer, we can connect the second coil as in the diagram.
The secret of the Tong Po Chi Coil is now totally out.  The World can now make use of this great invention.
The unbalanced force can be measured and controlled.  One important element is the pulse rate or frequency.
Devil
Tseung et al,
Do you know what you are doing?
You have
(1)   Showed that an unbalanced force can be produced from within a closed system.
(2)   You first achieved it with one Coil, two magnets and two unequally padded surfaces.  You were using the unequal conversion of energy into other forms at the two surfaces.  That effect can be demonstrated but is of little practical use.
(3)   Tong Po Chi improved that by using two Coils and one Magnet.  He further demonstrated that the attraction technique would produce the equivalent of collision without actually hitting any surface.
(4)   The unbalanced force effect can be increased and controlled.  The frequency of the pulsing DC current is an important factor.  This explained the many observed anti-gravity effects easily.
(5)   Dr. Raymond Ting and Mr. Lung in Shenzhen helped to produce an educational product that will be a standard laboratory apparatus in all Schools and Universities.
(6)   Ms. Forever Yuen and her student friends are testing the prototypes and producing the scripts on this educational product.
(7)   The generating of an unbalanced force from within a closed system is no longer  a myth but an absolute reality.  The man-made flying saucer in the coming future will not need to eject hot gases as the source for propulsion.
Do you know the impact of this on the Space Programs of the many Nations?
Do you know the military significance of such technology?
Do you know that the combination of this with Lead-Out Energy Machines will totally change the World as we know it?  The Nation that can master such technologies first will easily dominate the World.
Do you understand why Governments are denying the existence of UFOs even though they are pouring billions in their research?
You have already opened the Pandora Box.  The secrets of the unbalanced force and the Lead-Out Energy Machines are out.  You et al may become the heroes or the curses of the entire human race.
Do not worry about the insults and jeers.  Let them recite the following 666 times.
(1) The Lead-out-energy from a horizontally pulled pendulum is equal to the vertical component of the tension times the vertical displacement.
(2) An unbalanced force can be generated from a closed system.  Secondary events using unequal exchanges of energy and momentum are used.
(3) The electromagnetic Coil can be a magnet, a collision mechanism and an electricity exchange mechanism.
chrisC
Quote from: Devil on May 06, 2009, 05:41:25 PM
Tseung et al,
Yes we do. It's called 'talking to yourself'! How exciting!
No one seemed to care? Maybe you guys should join another forum, like a forum where people make up entities to communicate with one another? Good luck to your entourage.
You lot must be lonely waiting for replies.
cheers
chrisC
Paul-R
Quote from: chrisC on May 06, 2009, 05:47:55 PM
cheers
chrisC
If this were to turn out to be the case, chrisC, you will have done your job. There may even be a bonus for you.
