ltseung888
初步测试
http://www.tudou.com/programs/view/GeCgi6MVodQ/
è¾"å...¥èƒ½é‡çš,,直流ç"µåŽ‹æ˜¯12Vã€,ç"µé˜»æ˜¯6 Ohms.  ç"µæµæ˜¯2 Amp (I=V/R)
è¾"å...¥ç"µçš,,每ç§'能量是 24 Watt (P =VI) ã€,但因为是è,,‰å†²ç"µæµã€,ç"¨ç"µæ—¶é—´çº¦ä¸ºè½¯è¾"å...¥çš,,å...«ä»½ä¸€ã€,约3 Watts.
è¾"出能量çš,,交流ç"µåŽ‹æ˜¯60Vã€,ç"µé˜»æ˜¯72 Ohm. ç"µæµæ˜¯0.82 Amp (I=V/R)
è¾"出ç"µçš,,每ç§'能量是49.2 Watt (P=VI) ã€,这些数据,都是从实验取得ã€,(初步ç"¨äº†12个采集线圈ã€,)
若以 è¾"出能量/è¾"å...¥èƒ½é‡ 计算,overunity factor or Coefficient of Efficiency
(COE) = 16.4 !(49.2/3)
能量守æ'定律å'Šè¯‰æˆ'们,COE不可能大于 1 ã€,所以å"¯ä¸€è§£é‡Šï¼Œæ˜¯æŽè'‹çš,,引出能量理论ã€,
Translation:
The first experimental measurements on the Tong Po Chi Pulse Motor.
Input side:
Battery at 12V, Resistance of the Pulse Coil = 6 Ohms.  The steady DC Current would be 2 Amps (I=V/R).  The Power or Energy Input per second = IV or 24 Watts.  This calculation is for steady current.  In our case, the current is pulsed.  It will be only 1/8 of the steady case.  In other words, the input energy per second is only 3 watts (24/8).
Output side:
The measured output with 12 collectors in series is 60 volts AC.  The steady AC Current is approximately 0.82 Amps.  The output resistance is 72 ohms.  Thus the output AC power is 49.2 watts (60 x 0.82).  These are initial experimental values.  We are confident that they can be further improved.
Thus the overunity factor is 16.4(49.2/3).  The Law of Conservation of Energy tells us that the COE cannot be greater than 1.  The only possible explanation within the frame work of the Law of Conservation of Energy and existing Physics is the Lee-Tseung Lead-Out Energy theory.  We did not create energy from nowhere.  We lead-out both gravitational and magnetic (electron motion) energy in this particular case.
Thus the Tong Po Chi Brushless Pulse Motor confirms the Lee-Tseung Theory.  The next task is to produce a 5 KW version for home use.  We shall have at least 10 Tong Po Chi Brushless Pulse Motors for demonstration at United Nations after the academics have double, triple checked the device and the measurements.
utilitarian
Quote from: ltseung888 on May 25, 2009, 05:38:32 AM
初步测试
I submit that the efficiency of this device can be much improved if it is never turned on.
chrisC
Quote from: TinselKoala on May 25, 2009, 11:21:02 AM
Get an oscilloscope and learn how to use it.
http://www.youtube.com/watch?v=K6mFNpiSHKw
@TK
After you've debunked many of these snake-oil salesman, it mush become easier, although the last one nearly got the better of us because he seemed 'honest' and 'sincere' to cry his heart out to someone's grave. That was the drama king.
Now, this guy is a little different. He actually is not faking it but he really thinks he's invented the pulse motor and applied his own 'Lead-Out' energy theory and made it an O.U device!
Fortunately, you don't need to debunk this; it's already dead before started except the other personalities weren't told the truth by the puppeteer!
cheers
chrisC
ltseung888
The unexpected pleasant surprise
From the pendulum under the Lee-Tseung pull analysis, we can get Overunity factor of 1.5.  The experimental measurement from the Tong Po Chi brushless pulse motor is over 16.  This is very encouraging.
After some careful analysis, we realized that if the lead-out energy were not immediately used, it would contribute to accelerating the wheel.  The higher rate of rotation will lead-out more gravitational and magnetic (electron motion) energy.  We burnt a few relays before we hit on the explanation.
Thus the 225 HP pulse motor and the 180 HP Liang car are not hoaxes.  We are on the right path to produce a 5KW Pulse Motor.  The 50watt proof-of-concept prototype is already successful.  Each participating student will build one.  We should have over ten working prototypes within weeks.
