0 Members and 96 Guests are viewing this topic.
ltseung888
Quote from: Devil on May 31, 2009, 07:05:50 PM
Top Gun,
You et al disclosed the secret of the Tong Po Chi Pulse Motor to the World.  Now everyone with some engineering background can build it.  What do you gain?
Are you that noble as to benefit the World without personal rewards?
We believe that the two technologies â€" Lead-out energy and man-made flying saucer are so significant that all Countries will use them.
There is a strong possibility that some Countries have already developed military products based on such technologies.  However, the various Governments have kept that as top-secret.
Our role is to bring the benefits to the entire World.  The technology should not just benefit one group or one country.  Our educational product will help the student to understand the entire field of Lead-Out Energy.  The crowning jewel in the DIY kit is the building of an actual Lead-Out Energy machine that can conclusively demonstrate overunity.
Since the product will be out, we do not mind that some people will learn about it a few months early.  The market is large enough for many players.  We are also sure that some stupid debunkers will persuade their Governments that such technologies are hoaxes.  They will get hammered by their Governments later on.
Lawrence Tseung
Director,
Help Seedlings Innovate Foundation Limited.
Pirate88179
Lawrence:
Gee, this sounds a lot like my Bedini replications.  Have your people looked into Bedini?
Bil
chrisC
Quote from: fritznien on May 30, 2009, 10:50:24 PM
60volts AC into a coil is a lot closer to zero watts. yes you have 600 ohms resistance but how much inductive reactance do you have? what was the currant? why do so many know so little of the basics of AC?
fritznien
Because Lawrence is NOT a electrical engineer and much less a scientist! He's in the snake oil business and this is a comedy show.
cheers
chrisC
ltseung888
Coming Improvements over the prototype on May 28, 2009
1.   Drive and Collector Coils are identical in construction.
2.   Drive and Collector Coils are interchangeable via manual switching (and under program control later)
3.   The sizes of permanent magnets and coils will have much better matching.
4.   The diameter of the outer stationary wheel will be closer to 1 meter.
5.   The number of coils and magnets will match and will have 16 pairs.
6.   The design is in slices and an additional slice can be added if needed.
7.   The Magnitude of the Pulse Current can be adjusted via variable resistor.
8.   The number of turns in the coil will greatly decrease and a test for the optimal will be done.
9.   There will be a minimum load (lights) to drain away the energy from the battery and the Lead-out energy so that the electronics will not burnt.
10.   Stationary permanent magnets will be placed to increase efficiency of the motor/generator. (changing magnitude and direction of external magnetic field).
11.   Better magnets, wheel material and other engineering
12.   Better sensor control â€" Different small magnets will give thinner pulse and hence less input pulse energy.
13.   External load sensing and control (may leave that for the next prototype).
14.   Recharging of the same battery or recharging a backup battery.
15.   Continuous running for at least two weeks with fixed load
16.   Continuous running for at least two weeks with varying load
17.         Output will also be pulsed DC.   May use capacitors to smooth later.
We shall be busy for a little while.  A few more prototypes may be needed before a commercial 5KW electricity generator can be perfected.  However, we are optimistic and ready for the challenge.
Lawrence Tseung
Director
Devil
Quote from: ltseung888 on June 01, 2009, 04:43:00 AM
Lawrence Tseung
Director
Tseung, there will always be room for improvement.  The existing prototype can already demonstrate overunity.  Use that opportunity well.
Imagine the positive things that prototype and the Lee-Tseung theory bring to Hong Kong, China and the World.  Get ready to promote, promote and promote.
Do not worry about the insults and jeers.  Let them recite the following 666 times.
(1) The Lead-out-energy from a horizontally pulled pendulum is equal to the vertical component of the tension times the vertical displacement.
(2) An unbalanced force can be generated from a closed system.  Secondary events using unequal exchanges of energy and momentum are used.
(3) The electromagnetic Coil can be a magnet, a collision mechanism and an electricity exchange mechanism.
