ltseung888
Day 3 Conversation with Mr. Lung
Lung: “Let us focus on the 16 magnets and 15 coils design.  How can you be sure that the coil can drive the large wheel?”
Tseung: “With one drive coil, there will be 16 pulses per second.  With 15 coils as drive coils, we have theoretically 15 x 16 = 240 the strength of one pulse.  With a large wheel, the force to produce the required torque is even less.  I have no doubt that the coils will be able to drive the large wheel.”
Lung: “To be on the safe side, we should do a set of tests to check out before building the large wheel.”
Tseung: “If we are going to do the tests, we should include the tests on the Collector Coils.  There is one trick we can always use â€" increase the strength of the external magnetic field via fixed permanent magnets.”
Lung: “Give me a few days to think about it.  The educational product does not need to include a 5KW generator.  Anything that conclusively demonstrates overunity will be fine.”
Tseung: “That is correct.  The students are building versions that can generate at least 50 watts to win the overunity prize and to sell to Mark at HK$100,000.  We are optimistic.”
Lung: “What will be the reaction from the 225 HP pulse motor or the Liang car people?  If our primitive wheel works, their much more sophisticated wheels must have worked?”
Tseung: “Their wheels are likely to be classified as top secrets.  I do not worry about them.  My interest is to benefit the World.”
chrisC
Quote from: ltseung888 on June 09, 2009, 09:06:27 PM
.....  Anything that conclusively demonstrates overunity will be fine.”
Well 423 pages and 1 Olympics event had elasped... Maybe we'll have to wait until 2012? Somehow, we know this wishy washy project is already a non starter.
cheers
chrisC
Paul-R
Quote from: chrisC on June 09, 2009, 09:25:22 PM
cheers
chrisC
Every time you make a post in this thread suggests to me that that Lawrence's motor is real.
Why, otherwise, would you bother?
chrisC
Quote from: Paul-R on June 10, 2009, 06:44:41 AM
@Paul-R
Strange fellow you are, Paul. Just because Lawrence and his entourage lead you to believe he has something up his sleeves does not mean there's O.U? There are dozens and dozens of snake oil people everywhere, some deliberately faking it (aka that roach MyLow), others whose egos are beyond their technical ability (aka AQ) and yet others truly delusional (and you know who).
That's why we have quality people like TK, Bill (Pirate), Utilitarian etc who question everything and demanded verifiable proofs. Of course there are people like me whose (unpaid) job is to irritate these snake oil people into giving up their make believe nonsense that simple minded folks like yourself might otherwise fall into the trap of worshiping their deity!
cheers
chrisC
ltseung888
Day 4 activities
1.   One of the Collector Coils was taken down and was used as a Drive Coil on the Prototype.
2.   It was placed close to one of the four magnets on the rim of the wooden wheel.
3.   When steady current was passed to produce attraction, the wheel can turn if we move the coil.  The magnet on the wheel will be attracted all the time and caused rotation of the wheel.
4.   When steady current was passed to produce repulsion, the wheel can also turn as in 3 but the force is noticeably less.
5.   When pulse current was passed to produce repulsion, the wheel jerked slightly but could not rotate the quarter of a revolution.  This means a slight movement of the finger could not initiate the rotation.
6.   However, with 15 Drive Coils acting simultaneously, the situation may be very different.  It will be a worthwhile experiment.
7.   When the Collector Coil was placed close to the spinning magnet on the rim, there was some jerky movement of the needle but no meaningful voltage was observed.
8.   When a permanent magnet was placed behind the Collector Coil, the jerky movement was more noticeable.
9.   More work needs to be done on this simulated “225 HP” configuration.  One technique is to draw the power out from the rotating axle.
