0 Members and 82 Guests are viewing this topic.
ltseung888
The Building of the Supporting Box:
Ms. Forever Yuen and Mr. Jacky Ko went to the workshop of Mr. Tong Po Chi.  They would like to have the Supporting box built.  They were encouraged to draft their design on paper first.
The task sounded simple.  However, there were many different ways of accomplishing such a task.  The initial draft would not produce a very strong Support.  It would need many nails and iron brackets.
With the help of Mr. Tong, the students completed a box type design.  They then put actual measurements on paper.  Mr. Tong then cut the pieces of wood with his electric saw.  The Students put in the nails.  Even Forever screwed in a few nails herself.  The exact sequence of nailing to produce a solid box was demonstrated.
The entire task took approximately 3 hours.  Some nuts and bolts were needed to secure the bearing assembly.
The circuit diagram to support 16 coils with a two -stage relay was outlined and discussed.  Some new magnets needed to be purchased.   It was a fruitful day.
Lawrence Tseung
Director
Help Seedlings Innovate Foundation Limited
A Box!
And a pretty poor one, too. That sure looks like particle board with veneer. And you've put nails (or drywall screws?) into it edgewise.
And it looks like you've had some trouble drawing and following lines.
I don't see any bloodstains, though, so I suppose you could call your box a "success".
Your statement about Forever "even screwing in a few nails herself" seems rather strange. Other than the fact that nails aren't screwed in at all, what makes it worth commenting about? Is Forever somehow handicapped? Does she have an aversion to screwing in nails?
Or is it, perhaps, that she is female, and females aren't expected to do this kind of thing where you come from?
Top Gun
Analysis of the New Prototype displayed on June 28:
(1)   There are 16 positions with predrilled grooves.  This allowed a possible of 16 magnets to slide closer or farther from the rim.
(2)   The magnets can be staggered to increase their strength.  The present arrangement allowed 1-4 magnets (30mm square).
(3)   The orientation of the magnets can be adjusted.  It is possible to drive the magnets at the rim in pairs for high efficiency.
(4)   The experiment of having a coil with approximately 6 ohms and thus 2 Amps to repel the rim magnets was successful.  The wheel could rotate at least 1/8 with a single drive coil.  The chance of the wheel accelerating with 15 or 16 coils is 100%.
(5)   The Pulse Rate is governed by the rim magnets passing the proximity switch.  The faster the revolution, the higher the Pulse Rate.  More energy can be lead-out by a higher Pulse Rate.
(6)   The circuit diagram of the two-stage relay using 0-16 drive coils is complete and appears to work both theoretically and practically.
(7)   Output energy can be drawn from the fast rotating central axle.  A larger wheel will need less Pulse Force to rotate.  The students can always scale up the diameter of the wheel.  The opposing force is the frictional force at the bearings which can be kept very small.
The New Prototype uses manual control of the 15-16 coils.  When an external load is added (to the rotating axle), different number of drive coils could be used to supply the Pulse Energy.  The supplied pulse energy could Lead-Out additional electron motion energy.  The amount of Lead-Out Energy is rotational speed dependent and could be many times the supplied Pulse Energy.
The secret of success of this New Prototype over the Newman or Bedini machines is the increased Pulse Rate with increasing rotational speed.  The rotational speed will be slowed down by the applied external load (more than 50 watts is a certainty.)
If the 225 HP Pulse Motor and the Liang 188 HP Motor were true but suppressed by Governments, the New Prototype will work.  The New-Prototype will not be program controlled yet.  However, demonstrating overunity is virtually assured.
The World will see how Forever, Jacky, Miller and other students win the overunity prize in the coming weeks.  The many other supporters will get their financial return via the educational products or Company going IPO.  The World will benefit from these Lead-Out Energy machines.
Top Gun
The technical barriers have been torn down one-by-one.  The intelligent scientists can see the remaining moves just like the end game in Free Cells.
The FreeCell comparison is apt.
Because just as in FreeCell, the best you can do is to break even.
You start with 52 cards, and you have 52 cards when you finish. You get out what you put in (minus losses).
ltseung888
Hello Mr. Tsueng. I would like to know if there are any opportunities for us to implement a smaller version of your magnet motor to produce power for our line of parking lot and street lights. We have many l.e.d. fixtures that have a wind turbine, vertical shaft design on the rear section of the fixture, however, we would like to incorporate your generator on a smaller scale for prototyping.
We would like to introduce these models to countries that do not have the capabilities to install the necessary infrastructure in these areas to create the power that is necessary to recharge a bank of super capacitors. The output capacity that we will require is 500 -1000 watts. Please contact me with any questions.
sincerely, sterling higashi eco Power Systems / Electric Vehicle Technologies99-1374 Koaha Pl.Aiea, HI 96701808-484-2800 office, 808-484-2811 fax.email: sterling@evtechhawaii.comwww.evtechhawaii.comwww.milesev.com
I believe the students will be able to meet the challenge of producing 300-1000 watts in the coming weeks.  Give them a chance to shine.
