Top Gun
Quote from: Pirate88179 on July 14, 2009, 12:49:34 AM
@ TK:
No, none of my motors go that fast it was a guy on youtube here:
http://www.youtube.com/watch?v=m1WkxHr0G6o&feature=related (150,000 rpm)
http://www.youtube.com/watch?v=V1oFzXOZnE8  (300,000 rpm)
My fastest is like Jonnydavro's single magnet, no bearing set up and I am using a diametrically magnetized tube.  The guy in the above videos is using a sphere and then what looks to be a small rod.  He clocks them with his scope.
Jonny has a laser tach and my set-up like his does about 15,000-18,000 rpm.  I never clocked my rotor set-up but it is fast (or I thought it was, ha ha) for a Bedini motor of that type.
Dear Bill,
Once the basic parameters of a Bedini Motor have been set (e.g. dimension, number and strength of magnets, Coil configuration), what other parameters could you use to keep the device spinning at a certain rate?
In the 225HP Pulse Motor and our prototype, we can vary the following:
1.   The number of active pulse coils (225 HP Pulse Motor can vary slice)
2.   The strength of the pulse current (via variable resistor)
3.   The timed on and off of a particular pulse coil (via timers)
4.   Taking the external load on or off (turn off some LEDs on the prototype when the wheel starts to slow down).
5.   225HP Pulse Motor does that via program control.  We use manual switching for now.
Thus for a given external load, we could maintain a more or less high and constant rotational rate.
Please discuss how that is achieved in the Bedini Motors you built.  Thank you.
Pirate88179
I use two 5k variable resistors wired in series in all of my motors.  This is how I discovered I have a "2nd gear."  (as seen in my video)
I can also place a 6 volt motor with a rubber wheel on it on my spinning rotor and get over 8 volts out of it with about a 20% slow down in main rotor speed.  This is also while charging another battery through the usual Bedini charging circuit.  This is not bad considering my input battery is 9 volts and it is charging a 9 volt battery as well.  I can light several leds from the "generator" 6 volt pick-up motor at the same time.
But, please check out Jonnydavro's work as he can run like 15 rotors all from inductance and take power from all of them using only one power coil.  he is   way in the lead on this technology.  I am just following the best I can and try to keep up.
Top Gun
Quote from: Pirate88179 on July 14, 2009, 06:33:49 AM
Thank you for the very helpful information.  You can vary the load and the input pulse current.  Good job.
We shall publish the full test results with the variable number of pulse coils.
I still want to know the single torque your motor can achieve with one pulse.  We could do the Dr. Ting test to see how high the magnet jumps and follow that with the turn of a static wheel when we provide the pulse current.
My gut feel is that - in a merry-go-round with a few boys running and pushing, a slow one will not contribute to speeding up the wheel.  He would only slow it down.
ltseung888
http://www.youtube.com/watch?v=jFS-e2R67u0
The absolute proof of Overunity Lead-Out Energy Prototype can be seen in the above video.
The confirmation figures will follow in the next few weeks.
We can now confidently claim that the 225 HP Pulse Motor is no hoax.  We can produce and test the >0.5 HP prototype in the garage of Mr. Tong Po Chi.
Improvement is being added.
nievesoliveras
Quote from: ltseung888 on July 18, 2009, 12:23:05 AM
Congratulations @ltseung888 !!!
I will like to have the correct information in order to replicate your lead out configuration.
Jesus
