Top Gun
Meeting at the Institute of Energy of Hong Kong
Engineer A: “How do you deal with the Pulsing Energy Input?”
Tong: “Initially, we just measure the current.  It fluctuates.  To our surprise, on steady operation, the value was almost constant at 2 Amp even if we turn on additional coils.”
Engineer B: “You should not use the 12 V as Input.  Most of the time, the current was switched off.”
Tong: “We initially use a factor based on the combined length of the magnet compared with the circumference of the wheel to account for that.  That value was about 0.29.  We later found a better way in measuring the voltage across the relay directly.  The average DC voltage can drop to 1.9V when we turned all the drive coils on.”
Engineer A: “What is the Hertz value of the Output?”
Tong: “It is rotational speed dependent.  It is definitely not 50 or 60 hertz.”
Engineer B: “What are your immediate plans now?”
Tong: “Build another prototype with high output in the range of 1,000 watts or more.  The Input will still be from the 12V battery.”
Engineer A: “What is the reason for the low Output in the existing prototype?”
Tseung: “I suspect that we provided too much pulse power even with 1 drive coil.  The small "supposed non-functioning" magnetic wheel put load on the system.  That helped to dissipate some of the energy.  It allowed us to get to the overunity pulse condition.”
James: "Your system was designed to push a fat lady.  When you replace her with a thin child, the force will be too high.  You have to reduce and control the pulse force.  Can you have a theoretical model to predict the force?  Experiment using trial and error method takes too long."
Engineer B: “It looks like you still need much more research before you can completely master this technology.”
Tong: “We are at the stage of the 10 second light bulb.  We need more resources.”
Engineer A: “We volunteer to listen to you and give our ideas freely.  However, we are not in a position to provide millions of dollars on research.”
chrisC
Quote from: Top Gun on October 15, 2009, 02:56:12 PM
It's easier than that. You just need to take your medication.
cheers
chrisC
Top Gun
The unexpected bonus from the Divine One
Tseung, I believe the magnetic wheel as a load on the axle is a gift from the Divine One.
Tong et al were focusing on providing the highest possible pulse force to the Wheel.  They hoped to use the Input Energy as efficiently as possible.  They never thought that they could have overdone it.
They could either reduce the pulse force or increase the load.  They know that one way of the increasing the load is via the Collector Coils.  They never considered the adding of load via the axle.
Now you have this additional tuning tool.  You can change its diameter, the number and position of the magnets.  It will help your tuning tremendously.
Treat it as a gift from the Divine One.  No Inventor I know has described it in known literature.
You may get it as an unexpected bonus when you put two or more wheels together. [/b]  But now you have it earlier.
Thank the Divine One.
spoondini
Top Gun - Did you forget to sign in as Tseung when posting this?  The style matches several of Tseung's previous posts exactly.
Quote from: spoondini on October 16, 2009, 10:04:10 AM
Where have you been. Tseung being topgun,devil.... is a fact he even wrote it in his book.
