Mr.Entropy
Quote from: ltseung888 on October 08, 2007, 12:16:53 PM
Please note the seemingly innocent use of the word punch instead of push changes the physical process totally.
May be Mr. Entropy can enlighten you more.
How so? I believe the lawyer is correct.  A punch is a force of short duration -- exactly as we have with the pendulum.  Energy is transferred via a short, but very powerful applied force, and this is entirely consistent with the definition of the word "pulse".
Is there some finess you could add to the definition of "pulse" that makes it clear why a punch doesn't qualify?
Mr.Entropy
Quote from: ltseung888 on October 08, 2007, 03:33:59 AM
So you see that a top professor at Harvard University has the similar concern and mental attitude as you.  Unless he has a working prototype in his hands, he will not discuss the issue further.  If he accepts the Lead Out theory without absolute and undisputable proof, he would put his reputation and possibly the entire Harvard University Reputation at stake.
Prof H is too polite to call Prof. Woo an idiot, and ended the conversation quickly to avoid wasting more of his time.
The fortunate thing is ? there are many working prototypes already - some inside China and some outside China.
Ah, yes.  The difference between Prof H. and I is that I have hope for overunity.
However, while there may be working overunity prototypes, they do not prove your theory unless your theory is simply that overunity is possible.
If your theory is useful at all, then it makes quantifiable predictions about overunity effects that can be tested.  So far, you have quite annoyingly made testable, quantifiable predictions about non-overunity effects, and untestable, unquantifiable predictions about overunity effects.  If that is all you have to offer, then your theory is useless.
hansvonlieven
G'day Lawrence and all,
I have promised Jeff to be a good boy and keep my sarcasm to myself, so I will confine myself to asking a couple of questions that are bothering me in relation to your "Lead Out Theory"
If I understand your theory correctly, what you are saying is that Newton is wrong when he says that every action causes an equal and opposite reaction.
In effect what you state is that the reaction to an action contains more energy and that the difference between the two can be "lead out" to produce work.
This is one hell of a big statement which is at loggerheads with everything we know and have established by experiment over a very long time regarding these phenomena.
You also have stated elsewhere that there are 4 new forms of energy known to Chinese researchers, presumably Lead Out Energy is one of them.
Which raises the question, what energy are we talking about.
You call it cosmic energy. Are we to understand that we are talking here about something along the lines of "pyramid energy" or "radionics energy", you know the stuff that can only be detected by using a pendulum or a dowsing rod and even then only by specially gifted people.
I am not a physicist as you claim to be. I am only a retired humble engineer (physics major at that) with over 40 years in the field. I have worked with flywheels, levers, gears, pendula etc in the course of my work. I also consider myself a rather observant man when it comes to machinery. It amazes me to learn from you that I have failed all these years to observe even a shadow of the phenomena you are talking about. It also amazes me that my teachers at university, both in Germany and Australia have to this day not come to grips with pendulum and flywheel physics and have been teaching us erroneous bullshit. It must be a conspiracy, or we are all idiots (Sorry Jeff)
Hans von Lieven
ltseung888
Quote from: Mr.Entropy on October 08, 2007, 12:32:44 PM
(*** May be I should have used the word "periodically repeated" instead of the word "pulse" ***)
Dear All,
Let me give an example of how the handling a fast moving object A towards a stationary object B affects the result.
The various ways of handling the situation include:
(1)   Send a missile to destroy object A.  Only the tiny pieces would hit object B.
(2)   Attach a device to object A.  The Device will try to slow object A?s velocity to 0.
(3)   Attach a device to object A.  The Device will push A 90 degrees in direction of motion. This will effectively deflect object A and even turn it 180 degrees without slowing it down.
We can all see that the results are different.
Let me apply the analogy to the Pulse Force required to Lead Out Gravitational Energy in the case of the Pendulum.
(1)   When the Pendulum Bob is at the maximum height position, Pull to give it additional height and/or tension of the string.
(2)   When the Pendulum Bob is at the lowest position with maximum velocity, increase its velocity.  The Pulse Force must be in the direction of the velocity.
(3)   When the Pendulum Bob is at any intermediate position, increase its velocity in its direction of motion.
These three ways will add additional energy to the Pendulum System.
If we do the following:
(1)   When the Pendulum Bob is at the lowest position with maximum velocity, apply a force in the opposite direction to motion (essentially slowing it down), Energy is effectively subtracted from the Pendulum Bob in terms of sound, heat, friction, deformation etc.
(2)   When the Pendulum Bob is at any Intermediate position, decrease its velocity in the direction of motion.  This will have the same effect as in (1).
(3)   The case of changing a Pull to a Push when the Pendulum Bob is at its maximum displaced position is a very special case.  Energy can be added in both situations.
One of the qualifying conditions in the Lee-Tseung theory is that the Pulse Force must be applied at the right time (normally at resonance).  We quoted the case of the swing.  In order for it to swing high, we must push it at the appropriate time.  Otherwise addition of energy will slow it down!
I hope this explanation will clarify the ?required pulse at the right time? in the Lee-Tseung theory.  It is NOT any pulse at any time.
Lawrence Tseung
The pulse in the right direction at the right time leads out gravitational energy.  Any Pulse at any Time is likely to lead out nothing.
ltseung888
Quote from: hansvonlieven on October 08, 2007, 03:36:36 PM
Hans von Lieven
I shall answer this one first as it is the easiest.  These 4 forms of new energy are:
(1) Energy from Still Air
(2) Energy from Gravitation
(3) Energy from Electron Motion (magnetic)
(4) Energy from Electon Motion (Electric or Electrostatic)
Thanks for reading the hundreds of posts in steorn.com.
Lawrence Tseung
Simple direct questions Lead Out easy direct answers
